Aloha Threat Zone Widget
2331
5
04-30-2012 07:32 AM
RobertScheitlin__GISP
All,
   I am pleased to announce yet a another widget.
If you are an emergency responder than you are likely familiar with NOAA'a ALOHA
(Areal Locations of Hazardous Atmospheres) is a modeling program that estimates threat zones
associated with hazardous chemical releases, including toxic gas clouds, fires, and explosions.
NOAA has developed ALOHA ArcMap Import Tools which allow you to import ALOHA threat zones
(also called footprints) into ArcMap 9.x and 10.x.
This widget allows for the plotting of the Aloha threat zones in ArcGIS Viewer for Flex.
This widget does not model or generate the chemical plume, It only imports the Aloha .pas
file and parses the file to plot the data in ArcGIS Viewer for Flex.
http://calhouncounty.maps.arcgis.com/home/item.html?id=06e2c33649c34c478a15dace967d0cddhttp://www.arcgis.com/home/item.html?id=06e2c33649c34c478a15dace967d0cdd
MLowry
Pretty cool Robert. Will give it a shot and check out the source. It is friendly with 3.0 right?
Oh, it seems I can not access https://calhouncounty.maps.arcgis.com/home with my Global ID.
I get the following message: "The resource you are trying to reach requires you to sign in." after entering my correct global ID/pw.
M Lowry,
   I have corrected the link above. I am not testing against 3.0 as it is not final yet.
MLowry
M Lowry,
New link works copy-pasted to browser.
I believe the current hyperlink endpoint is still pointing to the old url location of your private arcgis.com, though.
Well done Robert. When is Esri going to hire you?
M Lowry,
   Thanks for the heads up. I have really fixed it this time. Be sure to let me know what you think about this widget.
omega_cancer
Thanks Robert, Its very nice to see your continuous contribution. 🙂
Keep it up.
