Advanced print solution
153428
296
02-19-2011 10:52 AM
TomSchuller
Please find in the codegallery my first version of an advanced print solution:
http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
The backend is developed in Java as a ServerObjectExtension: PChPrintSOE
The communication to the SOE is realized by the REST.
So, any client can be used Flex, Javascript, ...
I just created a simple FlexWidget.
Some features:
- full print over the rest api (usable by any client)
- export to pdf,jpeg,png,emf and mxd!
- view paper layout extent live on map
- make print on a "template" mapservice by keeping the predefined layout
- multi-mapservices/multi-server support
- add graphics on the map view positioned in map units
- add elements on the layout view positioned in paper units like scalebar, scaletext
The code is under full development:
- support for wms layer
- code clean up and reorganization
Any suggestions, remarques or help is welcome.
Live demo with public Esri mapservices (last print button):
http://gis.pch.etat.lu/flexViewerPrint/
   - use this print widget with your PChPrintSOE-enabled mapservices for high quality
   - draw first some graphics with the DrawWidget prior making your print (in mxd format)
EricVenden
Good morning (here at least) Tom,
I had your advanced print widget working in 2.4 viewer - with some tweaks to the uncompiled code.  I am now trying to implement the widget you created in the 2.5 viewer.  I have many compile errors.
As I type this - it appears that the latest files I downloaded did not have the json folder.  When I added this folder to my Flash project, I received even more errors - mainly AgsJsonElement related errors found in the PchPrintWidget.mxml & the PopUp_pictureElement.mxml files.
Could you advise?
Thanks for your time.
Eric V
TomSchuller
Hy Eric,
I just downloaded the latest sources of the bitbucket page:
http://bitbucket.schuller.lu/pchprintwidget/get/f79824d69e04.zip
I also downloaded the FlexViewer 2.5:
https://github.com/ArcGIS/ArcGISViewerForFlex/zipball/flexviewer-2.5-src
I copied from the pchprintwidget the complete "src" directory to the flexviewer src directory (asked to override the config.xml)
I added the "src\lu\etat\pch\gis\widgets\pchPrintWidget\PchPrintWidget.mxml" as module in the FlashBuilder project.
It compiled successfully and worked out-of-the box.
How did you downloaded the latest source?
Which small tweaks did you added to your version? May be I could integrate them directly in the codebase?
Tom
EricVenden
Thanks for the quick reply Tom,l
I just downloaded the code you posted, added the PchPrintWidget.mxml to the project and it came up with 10 errors.  I am using the 4.1 SDK with FB 4
One thing I noticed is that the lu_assets folder is not in the download you referenced in your post to me...but that shouldn't matter for my issues, I believe.
The errors are referencing the PopUp_Template.mxml (Type was not found or was not a compile-time constant: AgsJsonElement)
and
the PchJSONUtils.as (Access of undefined property - AgsJsonRGBColor, AgsJsonSimpleFillSymbol,AgsJsonSimpleLineSymbol, etc
Thanks Tom
Eric V
Hy Eric,
Tom
TomSchuller
Eric,
could you mail me your project?
[email protected]
I will check it. Seems to be something wrong.
I'm currently on Flex SDK 4.5.1
Tom
EricVenden
OK Tom,
Not sure if you got my email...but - I created a brand new project from scratch - did exactly as you stated in the previous post....and I get the same errors....
The errors are on lines 15&21 of the PopUp_Template.mxml file (Type was not found or was not a compile-time constant: AgsJsonElement)
and on lines 12,13,61,63,96,100,120,122 of the PchJSONUtils.as file - all those lines reference some symbol
I do see that the json folder (in the was missing from the "latest" download also)
I will add this folder and test
I am using the 4.1 SDK - I may also attempt the 4.5.1 version.
Eric
Eric,
[email protected]
Tom
EricVenden
Tom,
I have tried numerous options.
FB 4 with 4.1 SDK - 2.5 Viewer loaded from scratch
FB 4.6 with 4.1 SDK - 2.5 Viewer loaded from scratch
FB 4.6 with 4.5.1 SDK - 2.5 Viewer loaded from scratch
with and without the json folder
I have attached a screen shot of the errors.
Eric
TomSchuller
Eric,
your project seems to miss some needed files.
You can get the complete sources under:
http://bitbucket.schuller.lu/pchprintwidget/src
   upper right corner "get source" -> zip file
Tom
EricVenden
Thanks for your patience Tom,
When I tried clicking on the "Get Source" button, I only received the compiled code files (.swf & xml), so I retrieved the files under the src listing on bitbucket that you posted and now I only receive 1 error - referencing the "title" tag in the PchPrintWidget.mxml document.
The error says "The entity "mdash" was referenced, but not declared"  (line 7)
If I comment this line out or replace this title tag with something else, I get another error referencing line 234 = "The reference to entity "s" must end with the ';' delimiter.
I apologize as I am not a developer, but only a hack.
Eric V
Eric,
Tom
TomSchuller
Eric,
when clicking on the "get source" button,
you should get this link:
This download should contain the binaries and the source files.
I also attached it to this post, so you can check if it solves your problem.
Tom
EricVenden
Thanks Tom,
That link contains ALL the files...The project is good now.
Thanks for your help.
Eric V
Eric,
Tom
