Advanced Java PrintSOE on ARCGIS Server .NET --Can't connect to server
5879
26
06-03-2011 06:24 PM
RuiboHan1
I was following Step 2 on http://gis.pch.etat.lu/flexViewerPrint/quickstart.html
At the setp of
soemanager.bat -a [server name] [domain name] [username] [password] PCHarcgisSOE.jar
I used the username and password to Arcgis server .net, which is ArcGISWebServices and mypassword, but got the error of
" AutomationException occured while connecting to server localhost.
Please check if username and pwd are correct or are members of agsadmin group.
AutomationException: null
Disconnecting from ArcGIS Server "null"....Done"
I am sure the username and pwd are correct and can also use them to log on the arcgis server manager, anyone has the same problem? Please help,  Tom?  Thanks in advance.
TomSchuller
Hy,
could you check if your user "ArcGISWebServices" is in the "agsadmin" group?
You have to take a user which is in the "agsadmin" group.
Tom
RuiboHan1
Hy,
Tom
Thanks for the reply, Tom.
Yes, it is in the "agsadmin" group, and I also tested with another user in this group,but got the same error.
TomSchuller
Hy,
are you using the latest version?
download latest JAVA code
download latest FLEX code
from http://www.arcgis.com/home/item.html?id=6809086326ea4c76bf026a32bb9dd698
Could you post your soemanager command line with all the parameters?
Tom
RuiboHan1
Yes, I used 30/05/2011 version. Besides, I tested the live demo http://gis.pch.etat.lu/flexViewerPrint/
, and got the error "An error occurs during print" after click the print button.
Here is my command lines:
cd C:\Program Files (x86)\ArcGIS\Server10.0\java\tools\soemanager
set PATH="C:\Program Files (x86)\ArcGIS\Server10.0\java\jre\bin";%PATH%
soemanager.bat -a localhost localhost [username] [password] PCHarcgisSOE.jar
then got the AutomationException error.
Ruibo
TomSchuller
Hy,
the command is correct.
On which ServicePack level are you (none,SP1 or SP2)?
Could you try with an other Java SOE?
Tom
RuiboHan1
ArcGIS Server .net 10 sp2
Win 7 ultimate x64 sp1
Are you suggesting using the old version of PCHarcgisSOE.jar there? I tried that and still get the same error. I have a feeling that it was stuck at the username and pwd check stage, instead of the java soe installation.
Are there any speical java modules I have to install in advance? I installed everything as instructed by ArcGIS server installation file.
my current java version "1.6.0_16"
Java(TM) SE Runtime Environment (build 1.6.0_16-b01)
Java HotSpot(TM) Client VM (build 14.2-b01, mixed mode)
TomSchuller
Hy,
no I meant a complete other Java SOE.
So we could find out if it's related to my SOE or a server/user configuration.
We are now on SP2 on AGS-Java.
The PrintSOE is running on AGS-Java server v10, v10sp1 and v10sp2.
I don't have the possibility to test on AGS-.net.
I know that people on AGS-.net v10 and v10sp1 have running the PrintSOE successfully.
Tom
RuiboHan1
Sorry, I don't know much about Java SOE,  where can I find a different SOE? Thanks, Ruibo
JimWard
Ruibo, Tom, did either of you ever find a resolution to this problem? I am having an identical issue, have tried different users (members of agsadmin), and been spinning my wheels with this. I keep trying different options for server names, domains, users, etc.
Same error.
The tool looks like a perfect solution to my map printing/export needs. Would love to implement this!
Any help you could offer would be great!
Thanks
Jim
