Adding a WMS layer
6074
11
05-09-2011 07:29 PM
MarkSmith1
I saw that the new release of the viewer includes a new Layer tag that allows you to overwrite the WKID sent to a WMS server. Does this mean you can add a WMS layer to a viewer that is using a projection NOT supported by the WMS service?
I'm trying to add the NRCan Toporama service to my viewer (which is using wkid 102100) but nothing is showing up in when I examine the response from the server in Fiddler I get an unsupported SRS message. The Toporama service does not support Web Mercator (102100).
Maybe I don't understand but the change at 2.3.1 made it sound like I could force the wms to use the viewers wkid.
Here is the tag I'm using:
<layer label="NRCan" type="wms" visiblelayers="hypsography" url="http://wms.ess-ws.nrcan.gc.ca/wms/toporama_en" wkid="102100" skipgetcapabilities="true" version="1.1.1"/>
BjornSvensson
Esri Alum
Yes, this is supported in 2.3.1.
You just need to change the wkid in your example.  You can't force the WMS server to use a WKID it doesn't support.  Instead you tell it to use an ID that it does understand - 900913 (Google's ID for Web Mercator).
    type="wms"
    version="1.1.1"
    visible="true"
    visiblelayers="limits"
    wkid="900913"
MarkSmith1
That did it! Thank you very much.
MLowry
I'm trying to configure a pop-up for a WMS, and it is not working. The WMS provides the right symbology, but for some reason does not have pop-up configuration.
Are pops usable with a WMS?
BjornSvensson
Esri Alum
No, popups are not supported for WMS.
"...the ArcGIS Viewer for Flex supports pop-ups windows for tiled and dynamic map services, as well as feature layers."
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Pop_up_configuration_files/01m30000002...
MLowry
Well WMS's are great to have for up to date information, but that's pretty worthless if the up to date information isn't accessible to the end user via pop-ups. I hope this is supported in a future release, or I hope I am misunderstanding how Flex Viewer is used to view WMS's.
GeraldLee__GISP
I have to agree. Viewing popups for WMS services would be a great enhancement. PLEASE consider including this functionality!!..
ElenaBachilo
I'm trying to add wms service (wms.ess-ws.nrcan.gc.ca/wms/toporama_en) to my flexviewer 3.0 web application. I add code displayed below into config file. Do I have to do something else to make this service visible?
Thanks
BjornSvensson
Esri Alum
Could you share the exact line of your config.xml?
Are you sure that URL is a working WMS service?
BjornSvensson
Esri Alum
No, that should be it.  Works fine when I test it
        <operationallayers>
                type="wms"
                version="1.1.1"
                visible="true"
                wkid="900913"
        </operationallayers>
What basemaps are you using? (Is it in a different projection than the Esri basemaps?)
