Adding a base map with cache
1562
10-29-2013 05:20 AM
DiegoLlamas
I am trying to add my own base map with cache. On the first step where I add the basemap I select ArcGIS Server using http://localhost:6080/arcgis/rest/services/mapas I select the service with cache and include it to selected basemaps. [ATTACH=CONFIG]28687[/ATTACH] but for some reason, when I use this basemap I can't see it [ATTACH=CONFIG]28688[/ATTACH] I just see a grey rectangle. The service is working perfectly when I add it on ArcMap. [ATTACH=CONFIG]28689[/ATTACH]
Am I doing something wrong?
Hope you can help!
Regards,
Diego Llamas
AnthonyGiles
Honored Contributor
Diego,
You need to specify what icon you what to use for your basemap.
To do this click on the pencil icon on your basemap layer which allows you to edit the settings for that layer. One of the options is to select an icon to use; You will of course have to create one to use or grab one from online such as:
http://www.arcgis.com/sharing/content/items/716b600dbbac433faa4bec9220c76b3a/info/thumbnail/imagery_...
http://fcsharepoint.co.frederick.va.us/_layouts/ESRI.ArcGIS.Mapping.SharePoint/config/basemap_tbs/bi...
http://www.geo-fia.org/_layouts/ESRI.ArcGIS.Mapping.Sharepoint/config/basemap_tbs/bingmaps_aerial.pn...
http://www.geo-fia.org/_layouts/ESRI.ArcGIS.Mapping.Sharepoint/config/basemap_tbs/bingmaps_hybrid.pn...
Regards
Anthony
