add ROLL_OVER on QueryWidget
4493
20
08-21-2014 03:46 AM
NatashaManzuiga
Hi, I 'm trying to add a ROLL_OVER function on mouseovergraphic
I added this line on createQueryResults..
graphic.addEventListener(MouseEvent.ROLL_OVER, mouseOverGraphic);
and the function:
private function mouseOverGraphic(event:MouseEvent):void
        var gra:Graphic = event.currentTarget as Graphic;
        var infoData:Object = gra.attributes;
        clearTimeout(hitimer);
        var queryResult:ResultItem = gra.attributes as ResultItem;
        if (map.extent.containsXY(queryResult.center.x, queryResult.center.y))
                // only show infowindow if query result in contained within map extent
            hitimer = setTimeout(showHighlight, 300, [ queryResult ]);
        else
            hideInfoWindow();
What I'm wronging?
Naty
RobertScheitlin__GISP
Naty,
  It is because the graphics attributes are not a ResultItem.
Here is the fix:
import mx.collections.ArrayList;
import com.esri.ags.components.ContentNavigator;
            private var contentNavigator:ContentNavigator = new ContentNavigator();
                var currentGraphic:Graphic = event.currentTarget as Graphic;
                var mapPoint:MapPoint = (currentGraphic.geometry.type == Geometry.MAPPOINT)? (currentGraphic.geometry as MapPoint) : currentGraphic.geometry.extent.center;
                contentNavigator.dataProvider = new ArrayList([ currentGraphic ]);
                // Put the ContentNavigator in the info window.
                map.infoWindowContent = contentNavigator;
                map.zoomTo(currentGraphic.geometry);
                map.infoWindow.show(mapPoint);
Naty,
Here is the fix:
NatashaManzuiga
It was impossibile for me to make it possible!!!
Thanks!!
I still have some problem to populate infopopup..with the PopUpRendererSkin.mxml ...because when I select a record on search result...it works well..when I ROLL_OVER on a Graphic...it doesnt show me title and description..
Naty,
   I am not sure I understand your problem. Can you provide screenshots?
Naty,
Try this instead:
                var resultAttributes:ResultAttributes;
                resultAttributes = graphicToResultAttributes[currentGraphic];
                popUpRenderer.popUpInfo = configurePopUpInfo(resultAttributes);
                popUpRenderer.graphic = currentGraphic
                map.infoWindow.content = popUpRenderer;
                map.infoWindow.contentOwner = popUpRenderer.graphic;
NatashaManzuiga
Robert, thanks, you fixed my problem...
I still have this problem when I graphically click on the feature..
Naty,
   The popup that you get from clicking on a feature is not controlled by the Query widget, it is controlled by the popup you have defined for the layer in the main config, that is why there is a difference.
NatashaManzuiga
And can I modify it....or at least....can I disable click on the feature?
Thanks Robert,
Naty
Naty,
   Sure you can just remove the popup portion that you specified for that layer in the main config.xml
NatashaManzuiga
In the main config.xml, I just have this line:
<widget url="widgets/Query/QueryWidget.swf" config="widgets/Query/QueryWidget_HealthEmergency.xml" label="Health and Emergency" icon="assets/images/19_icon.png"/>
