Add Placemark
4950
03-07-2015 10:30 PM
MohammedKhamis
Dear All ,
There is way to get coordinate from flex , Actually there is tool on the Google Earth called Add Placemark , it can import coordinates from web .
I need tool like it to do the same idea ..
Any widget support that ??
in the attached Add Placemark by Google earth ..
many thanks for helping
RobertScheitlin__GISP
Mohammed,
   This is the closest widget that I could find.
Coordinate Menu Widget
http://www.arcgis.com/home/item.html?id=edd4a2b7c722493a8b08f53eaa131e1e
Mohammed,
MohammedKhamis
Thank you Robert ..
there is update about it ? because I want using for 3.7 or 3.6.9 version ..?
many thanks for supporting .
Mohammed,
   I am pretty sure the 3.6 version will work in 3.7 (I have not tested this though).
