Access TOC from widget
2714
9
11-02-2011 09:13 AM
RavinHasseea
I would like to change the TOC as follows:
1. Turn on a sub layer automatically from a separate widget
2. Switch off all sub layers when group layer is switched off
3. Switch on group layer automatically when a sub layer is turn on
4. Disable / Enable a TOC node from a separate widget
Is this feasible in the Flex Viewer?
FaizanTayyab
Are you using the widget from the gallery for the TOC.
If you search the forums, you should be able to find a way to achieve the above.
I had to do something similar for creating a session save widget (saves user session to a file and allows sharing of sessions).
Code which helped me (again found from the forum search):
var visLayers:ArrayCollection = dmsl.visibleLayers;
var newVisLayer:ArrayCollection=new ArrayCollection(obj.visLyrs.visibleLayer);
for each(var j:int in newVisLayer){
AppEvent.dispatch(AppEvent.LAYER_VISIBILITY_CHANGED,j);
In TOCitem
public function TocItem( parentItem:TocItem = null )
 _parent = parentItem;
 //ViewerContainer.addEventListener(AppEvent.LAYER_VISIBILITY_CHANGED, updateCB);
 AppEvent.addListener(AppEvent.LAYER_VISIBILITY_CHANGED,updateCB);
private function updateCB(event:AppEvent):void
 if(this is TocLayerInfoItem)
           var tli:TocLayerInfoItem = this as TocLayerInfoItem;
  if(tli.layerInfo.id == event.data){
   setVisibleDirect(_visible ? false : true);
RavinHasseea
Hi I have tried the suggested above. I turn on a layer from a widget. This works fine.
Then dispatch an event. The code setVisibleDirect(_visible ? false : true); is run
however, when I open the layerList widget, the checkbox for the layer is still not ticked.
Am I missing out something?
Thanks
FaizanTayyab
i modified the code as below to make it work but i had to do alot of other custom code in my widget, but this might give you some idea.
   var disObj:Object=event.data;
   //if(disObj.mainLayer!=null){
    if(tli.rootInfo.name==disObj.mainLayer || disObj.mainLayer==null){
    //var tmpLayer:ArcGISDynamicMapServiceLayer=disObj.mainLayer;
    if(tli.layerInfo.id == disObj.index){
     //this.preventPropogation=true;
     if(disObj.visibility==false){
      this.setVisibleDirect(false);
      //this.visible=false;
     if(disObj.visibility==true){
      this.setVisibleDirect(true);
      //this.visible=true;
     if(tli.isGroupLayer()){
      AppEvent.dispatch(AppEvent.VISIBLE_LAYERS_RETURNED,tli.layerInfo.id);
    }// end of mainlayer if
RavinHasseea
I would have thought it would quite common to switch on a layer without using the toc. But the solution isn't obvious. Below doesn't work. Any ideas??
layerlist contains sublayers to switch on..
for (var i:int = 0; i < layerList.length() - 1; i++)
      var servicename:String = layerList.@service;
      var layerno:String = layerList.@layerno;
      var vizLayers:Array = new Array();
      vizLayers.push(layerno);
      for each (var layer:Layer in map.layers)
       if(layer.name == servicename)
        var MapLayer: ArcGISDynamicMapServiceLayer = layer as ArcGISDynamicMapServiceLayer;
        MapLayer.visibleLayers = new ArrayCollection(vizLayers);
        var visLayers:ArrayCollection = MapLayer.visibleLayers;
        visLayers.addItem(layerno);
        MapLayer.visibleLayers = visLayers;
        MapLayer.refresh();
      var data:Object =
        layerid: layerno,
        visibility: true
      AppEvent.dispatch(AppEvent.LAYER_VISIBILITY_CHANGED,data);
private function updateCheckBox(event:AppEvent):void
   var obj:Object=event.data;
   if(tli.layerInfo.id == obj.layerid)
    if(obj.visibility == true)
The required layers are switched on the map. But no change in TOC.
RavinHasseea
rockzZ25, I am trying to follow your suggestion above. How do you obtain rootInfo in
tli.rootInfo.name?
Also disObj.mainLayer?
Thanks
FaizanTayyab
I modified tocLayerInfoItem
// Copyright � 2008 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/FlexViewer/License.txt
package com.esri.viewer.components.toc.tocClasses
 import com.esri.ags.events.ExtentEvent;
 import com.esri.ags.layers.ArcGISDynamicMapServiceLayer;
 import com.esri.ags.layers.Layer;
 import com.esri.ags.layers.supportClasses.LayerInfo;
 import com.esri.viewer.ViewerContainer;
  * A TOC item representing a member layer of an ArcGIS or ArcIMS map service.
  * This includes group layers that contain other member layers.
 public class TocLayerInfoItem extends TocItem
  public function TocLayerInfoItem( parentItem:TocItem, layerInfo:LayerInfo,tLayer:Layer)
   super(parentItem);
   // Added line below
   _rootInfo=tLayer as ArcGISDynamicMapServiceLayer;
   _layerInfo = layerInfo;
   label = layerInfo.name;
   // Set the initial visibility without causing a layer refresh
   setVisible(layerInfo.defaultVisibility, false);
   ViewerContainer.getInstance().mapManager.map.addEventListener(ExtentEvent.EXTENT_CHANGE,checkExtent);
  internal static const DEFAULT_MAX:Number = 0;
  private var _maxScale:Number = DEFAULT_MAX;
  public function set maxScale( value:Number ):void
   _maxScale = value;
   this.scaledependant = true;
   if (_maxScale > 0 ){
    if ((ViewerContainer.getInstance().mapManager.map.scale >= _maxScale)){
     this.scaledependant = false;
   } else if (_minScale > 0 ) {
    if ((ViewerContainer.getInstance().mapManager.map.scale <= _minScale)){
   } else {
  public function get maxScale():Number
   return _maxScale;
  private function checkExtent(evt:ExtentEvent):void{
   } else {
  internal static const DEFAULT_MIN:Number = 0;
  private var _minScale:Number = DEFAULT_MIN;
  public function set minScale( value:Number ):void
   _minScale = value;
   } else {
  public function get minScale():Number
   return _minScale;
  //  Property:  layerInfo
  private var _layerInfo:LayerInfo;
   * The map layer info that backs this TOC item.
  public function get layerInfo():LayerInfo
   return _layerInfo;
  //   Property: _rootNode
  private var _rootInfo:ArcGISDynamicMapServiceLayer;
   * The map layer root behind this TOC item.
  public function get rootInfo():ArcGISDynamicMapServiceLayer
   return _rootInfo;
  //  Methods
   * @private
  override internal function setVisible( value:Boolean, layerRefresh:Boolean = true ):void
   // Set the visible state of all children, but defer the layer refresh
   for each (var item:TocItem in children) {
    //if(super.preventPropogation==false){
     item.setVisible(value, false);
   // Set the visible state of this item, but defer the layer refresh
   super.setVisible(value, false);
   // Allow the layer refresh now that all changes have been made
   if (layerRefresh) {
    refreshLayer();
FaizanTayyab
The code below, loads a user session file
var bytes:ByteArray=lfileRef.data;
    this.loadedObj=bytes.readObject();
    map.scale=loadedObj.scale;
    map.extent=loadedObj.extent;
    var layerIDsArr:Array = map.layerIds;
    for(var i:Number = 0; i < layerIDsArr.length; i++)
     var tmpLayer:Layer = map.getLayer(layerIDsArr);
     for(var j:Number=0;j<loadedObj.objs.length;j++)
     if(tmpLayer.id==loadedObj.objs.mainLayer.toString()){
      tmpLayer.visible=true;
      this.hideLayerItem=new Array();
      if(tmpLayer is ArcGISDynamicMapServiceLayer){
       var dmsl:ArcGISDynamicMapServiceLayer=tmpLayer as ArcGISDynamicMapServiceLayer;
       this.loadedLayer=null;
       // Remove all checks and also remove any visible sublayers
       for each(var lyrInfo:LayerInfo in dmsl.layerInfos){
        this.hideLayer(dmsl,lyrInfo);
       // handle the group layers and call the handler to
       AppEvent.addListener(AppEvent.VISIBLE_LAYERS_RETURNED,handleVisibleLayers);
       this.loadedLayer=dmsl;
       for each(var k:int in loadedObj.objs.visibleLayer){
        var disObj:Object=new Object();
        disObj.index=k;
        disObj.visibility=true;
        disObj.mainLayer=dmsl.name;
        AppEvent.dispatch(AppEvent.LAYER_VISIBILITY_CHANGED,disObj);
       // Code below to make the child of group invisible but maintaining the tick of the group
       var newVisLayer:ArrayCollection=new ArrayCollection(this.loadedObj.objs.visibleLayer);
       for (var x:int=0; x<newVisLayer.length;x++){
        for(var y:int=0;y<this.hideLayerItem.length;y++){
         if(newVisLayer==this.hideLayerItem){
          var idx:int=newVisLayer.getItemIndex(this.hideLayerItem);
          newVisLayer.removeItemAt(idx);
       this.loadedLayer.visibleLayers=newVisLayer;
     } // end of inner for
RavinHasseea
Thanks for this. Does it work with the default layerlist widget ?
FaizanTayyab
sunsilk10,
I haven't tried it with the default layerlist widget but i think with some tweaking it should work.
As making this work required changes in multiple places within the application, I couldn't create a complete save session widget but with all those changes/additions, the save session code works fine for me.
