3.2 Attribute Table copy
2445
04-22-2013 07:46 AM
KennyHoran
My users like the Attribute Table but they'd really like to copy data from the Attribute Table and paste it elsewhere.  Might I place an enhancement request for this feature?
Alternately I see an Event.COPY event fires on the Attribute Table when a user presses Ctl+C, but now I'm stuck on how to get at the data.  How do I access the selected items in an Attribute Table?
Edit: Found the selected items in AttributeTable.featureLayer.selectedFeatures
SarthakDatt
Hey Kenny,
If you look under the 'Table Options' menu, there is a way to export the data to a CSV file. If there are any features selected it would only export those, otherwise the entire feature set.
KennyHoran
That's handy but just doesn't cut it (pun intended). My users want a simple Ctrl+C just like how Excel works. Here's an extension I wrote to illustrate.
<?xml version="1.0" encoding="utf-8"?>
AttributeTableWidget extension for ArcGIS Flex Viewer 3.2
Adds copy feature to Attribute Table via keyboard and right-click menu.
To use, configure the AttributeTable widget and substitute this file for "AttributeTableWidget.mxml" in your config.xml
<AttributeTable:AttributeTableWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:AttributeTable="widgets.AttributeTable.*"
         widgetConfigLoaded="basewidget_widgetConfigLoaded()">
 <fx:Script>
  <![CDATA[
   import com.esri.ags.Graphic;
   import com.esri.ags.components.AttributeTable;
   import flash.events.ContextMenuEvent;
   import spark.components.NavigatorContent;
   /** Listen for new AttributeTables being added to viewStack */
   private function basewidget_widgetConfigLoaded():void
    viewStack.addEventListener(ChildExistenceChangedEvent.CHILD_ADD, childAddEvent);
   /** Add copy listener and menu item to the new AttributeTable */
   private function childAddEvent(event:ChildExistenceChangedEvent):void
    var attributeTable:AttributeTable = (event.relatedObject as NavigatorContent).getElementAt(0) as AttributeTable;
    attributeTable.addEventListener(Event.COPY, attributeTable_copyHandler);
    var contextMenu:ContextMenu = new ContextMenu();
    contextMenu.hideBuiltInItems();
    var customItem:ContextMenuItem = new ContextMenuItem("Copy selected");
    customItem.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, customItem_menuItemSelectHandler);
    contextMenu.customItems.push(customItem);
    attributeTable.contextMenu = contextMenu;
   /** Copy selected rows to the clipboard Excel style */
   private function attributeTable_copyHandler(event:Event):void
    var rows:Array = [];
    for each (var graphic:Graphic in (event.currentTarget as AttributeTable).featureLayer.selectedFeatures)
     var newRow:Array = [];
     for each (var value:String in graphic.attributes)
      newRow.push(value);
     rows.push(newRow.join("\t"));
    System.setClipboard(rows.join("\r\n"));
   /** Dispatch a COPY event when clicked */
   private function customItem_menuItemSelectHandler(event:ContextMenuEvent):void
    (event.contextMenuOwner as AttributeTable).dispatchEvent(new Event(Event.COPY));
 </fx:Script>
</AttributeTable:AttributeTableWidget>
It'd be great to have a similar capability in a future release. This code is retyped, so I apologize in advance for any typos.
