3.1 ResultAttributes extra newline
2738
03-08-2013 02:45 PM
KennyHoran
I've been playing with the SearchWidget and noticed that when the InfoWindow scrolls there's extra whitespace at the bottom. I've tracked it down to an extra newline in supportClasses.ResultAttributes
The newline can be removed by truncating "content" after it's built, or by prepending the newline instead.
Truncate example:
// Line 76
if (content.length > 0 && content.charAt(content.length - 1) == "\n")
  content = content.substr(0, -1);
resultAttributes.content = content;
Prepend example:
// Line 154 - 161
if (textDirection && textDirection == "rtl")
  content += (content.length > 0 ? "\n" : "") + value + " :" + fieldLabel + "\n";
else
  content += (content.length > 0 ? "\n" : "") + fieldLabel + ": " + value + "\n";
Hope this is handy.
BjornSvensson
Esri Alum
Thanks for the suggestion.  Getting rid of that extra ending newline is a good idea.  We will do something similar to what you suggested. You can keep track of the progress at https://github.com/Esri/arcgis-viewer-flex/issues/84
BjornSvensson
Esri Alum
Just wanted to follow up and let you know that this has been fixed and will be part of the 3.2  release (see GitHub Issue #84).
FYI - you can see the exact code change of our "commit" on GitHub:
https://github.com/Esri/arcgis-viewer-flex/commit/11546fcf7d2d598fd44b2eece569fcf2d997c0a0
FYI: if you want to see what other viewer code changes made it into 3.2, look at the 58 closed and verified issues for 3.2:
https://github.com/Esri/arcgis-viewer-flex/issues?labels=verified&milestone=1&state=closed
