2.5 Chart Widget problem.
1109
12-12-2011 02:30 PM
SeanCook
I just migrated to 2.5, and would love to be able to use the chart widget, but it appears to have a very limited functionality unless I am missing something.
Robert's previous chart widget could support multiple fields, i.e. the following table could make a chart with two slices, Male (400) and Female (425):
State, Male, Female
CA, 200, 250
AZ, 100, 75
NV, 100, 100
The new chart widget appears to only work with a single field. This means that same table could only produce a pie chart where a single field is chosen with the following three slices, e.g. for males: CA (200),  AZ (100), NV (100).
This invalidates all the charting I do. Is it possible to derive the top Male/Female example with charting widget 2.5? If not, when will this obviously necessary functionality be added?
MattShetzer
Did you ever get a response on this?
Matt
State, Male, Female
CA, 200, 250
AZ, 100, 75
NV, 100, 100
PawanVuppala
Has anyone found a work around to add multiple fields in 2.5 chart widget?
Thanks!
Matt
