Not Able To Create Output Layer or Add a Source Feature Layer to B.D.A.
2752
7
06-16-2023 12:41 PM
ArmstKP
Anybody else having issue creating an output layer?  When I click the "Next" button, nothing will happen. I have given it minutes, but to no avail.  Have tried it with different browsers also.
ArmstKP
@RyanChase_EsriUK There is a workaround to this issue, until the next update is released.  The workaround was suggested by ESRI Tech support, which I have used and has worked.  If you stop your scheduled analytic, then choose the analytic to run only once, save that, then add in your output or source layer, save again, then reschedule, save and then run the analytic.  I guess there is a bug after the last update that deals with scheduling.
PeterNasuti
Hello @ArmstKP! there were lots of user interface changes with our recent release that went out last week. Please clear your browser cache and reopen Velocity in a new tab. If the issue persists please log an Esri Support Services case for the reported issue for assistance and a workaround if needed. Thanks!
RyanChase_EsriUK
Hi @PeterNasuti
I am also having the same even after the advice above. Thought it would be good to mention it is not an isolated issue that ArmstKP is experiencing.
My case is with Esri Inc Technical Support.
Cheers!
ArmstKP
@RyanChase_EsriUK @PeterNasuti I am also not able to add a source feature layer to any of my big data analytics.  I tried all the suggested solutions as well.  I have also created a case.
ArmstKP
@RyanChase_EsriUK @PeterNasuti UPDATE:  After having a screenshare with technical support, this issue only looks to happen to big data analytics that were created before the recent AGOL and Velocity updates.  If I clone my data analytics and then try to add a source feature layer or add an output layer, it will work...
RyanChase_EsriUK
@ArmstKP Thank you for the update. Great to hear you have a workaround. Unfortunately I have tried this method previously and the issue here is that all new outputs are created when cloning - when I try and replace the outputs with the existing feature layers (that have had no issues) it then throws up Schema errors!
I want to avoid having to redo the entire workflow but I shall see what Esri Inc Tech Support suggest as well.
ArmstKP
@RyanChase_EsriUK  I want to avoid it as well.  It is not a solution for me either.
ArmstKP
