Vector Tile Style Editor - Language issues
1371
10-29-2024 05:06 AM
KenanCerimagic
Good afternoon,
Is there a way to manually change the text of a single label?
I've changed the display Language of the map, and almost all work well, but a few labels are in the wrong alphabet or have spelling mistakes. For example, two US states have the wrong spelling, and some major US cities have the wrong alphabet.
Tnx
John-Foster
There is a recent blog post about changing labels using the Vector Tile Style Editor: https://www.esri.com/arcgis-blog/products/arcgis-living-atlas/announcements/changing-labels-in-esri-...
--jf
Georgios-NektariosTselos
Hello @KenanCerimagic , i think you could do it from the attribute table manually , make the changes and then save the new. Also you can dublicate the file and in the copied make the same changes for more safity
Best Regards
Nektarios
KenanCerimagic
It looks it there is something deeper in the system 🙂
I've used labels as a workaround, at least for the top level.
John-Foster
--jf
