Will the UN Data Model work with ArcGIS for AutoCAD - Free Plug-In between AutoCAD & ArcGIS?
3664
9
08-25-2023 02:21 AM
CMSchelde
I curious to find out if the Utility Network data and model can work with the ArcGIS for AutoCAD - Free Plug-In for Interoperability Between AutoCAD & ArcGIS? - https://www.esri.com/en-us/arcgis/products/arcgis-for-autocad
Can someone at Esri provide me with some information about this and if it is even being considered or if it is already on UN Road Map.
Thanks in advance for your help with my question.
Colleen Madigan Schelde - [email protected]
Nexel
PierreloupDucroix
MVP Regular Contributor
the main issue is that ArcGIS for AutoCAD cannot connect to a named version. You can draw in a UN service, but only in the Default branch, which is not a standard workflow in Utility Network. Otherwise, it works, you can create feature and dirty areas will be created in ArcGIS. But network rules won't be honored in AutoCAD (no snapping rules, no associations...). Attributes rules should work since they are on the server side.
I tried to register a UN service in my Portal with the "gdbversion" parameter set to a named version to see if it works in AutoCAD without success. Maybe there are other ways to do that, but I don't know.
Being able to edit a named version un AutoCAD is the most important thing to be compatible with UN and branch version workflow.
CEO of MAGIS
PierreloupDucroix
CEO of MAGIS
CMSchelde
Pierre -
Thanks for your response and input.
Best regards,
Colleen
PierreloupDucroix
You're welcome,
it would be great to hear Esri staff about this compatibility between applications and UN workflow.
Maybe the branch versioning team or AutoCAD team may have solutions or workarounds.
CEO of MAGIS
JimmyBowden
Over a year ago I posted an Idea to allow read access to branch version data in ArcGIS for AutoCAD.  It is currently "under consideration".
CMSchelde
Thanks Jimmy for your input!
PierreloupDucroix
hi @Randy_Garcia
do you have some news about our topic ?
CEO of MAGIS
Randy_Garcia
Hi Thanks for the mention @PierreloupDucroix
One of the big things in supporting UN is branch versioning as mentioned in this thread. The team is currently working on implementing this as will hopefully be available in the next release Version 430. We are looking for a release very late this year/early new year.
With that said, there is a lot more to do in order to support UN properly, right now ArcGIS for AutoCAD can edit and work with web feature layers. While branch will let you bring in the UN layers and work with them we still need to do things to make sure we are being a good "citizen" in supporting UN workflows. When we release branch versioning support we still aren't doing anything to support UN specifically. While it gets you a lot closer there are still going to be gaps you will come across. We hope the gap will get smaller every release. If there are specific things about UN outside of branch versioning that you would like to see in ArcGIS for AutoCAD please feel free to submit an idea.
I hope that helps!
mfafard
I’m just trying to bring pipes and hydrants from UN to ArcGIS for AutoCAD (V435), but it doesn’t seem possible. Right?
AyanPalit
@mfafard You should be able to pull the data from the default version of the geodatabase as well as reference map services.
also, at 430 release of ArcGIS for AutoCAD:
Ayan Palit | Principal Consultant Esri
