Water Utility Network - Model Blow-Off
822
10-30-2025 10:20 AM
ModernElectric
I am currently building our Water Utility Network and working with the Blow-Off features within our infrastructure. Trying to determine the best path for connectivity.
Presently, I have the Blow-Off feature within Water Devices - Flushing and Blow Off. However, the connection from a water line - service (Blow-Off) isn't connecting.
Is there a different connection I am not aware of OR do I need to update the connectivity rules to allow that to happen?
Appreciate the feedback.
gis_KIWI4
MVP Regular Contributor
@ModernElectric - You are on the right track. There needs to be a connectivity rule for this combination otherwise it will not work. The first sign is that the snapping-chip doesn't appear when trying to connect element that do not have a connectivity rule.
Could you confirm there is a rule for these two element to connect.
Also make sure the ASSETGROUP and ASSETTYPE are set when trying to connect them in Pro.
ModernElectric
@gis_KIWI4
That is what I was thinking it was, looks like I was second guessing myself. I would have thought those rule(s) were already built in prior to the publishing of the solutions package.
I will comb thru the rule(s) and update accordingly.
PatrickGCowan
You are correct. It looks as though there are some rules missing for the Flushing and Blow Off asset group that should be there. We will get those added for the next update. In the meantime, you can add the needed rules manually.
