Vertical Assets represention
1708
04-05-2024 08:30 AM
Aymen_Farhat
How should vertical assets such as fittings or valves be represented within a utility network.
RobertKrisher
The term vertical assets is typically used when referring to equipment located inside plants/stations. The model includes the ability to model the location of fittings and valves in both 2d and 3d space, regardless of whether they are installed inside plants/stations (i.e. vertical assets) or in the field.
BillFox
MVP Notable Contributor
are you doing this in high accuracy z-aware GPS / RTK in ortho-metric height in feet with good 3D elevation surfaces?
Aymen_Farhat
Yes we are using GPS\RTK and  we use field maps to collect data, The issue is how to visualize lets 2 fitting they are in top of each other with different z value.
BillFox
are you thinking of making a paper run book / map series or something in field maps / scenes, or augmented reality options?
Aymen_Farhat
Yes for field maps can it consume web scene.
