UNTools for ArcGIS Pro 3.5.x
1938
6
09-04-2025 05:59 AM
SanchezNuñez
Good afternoon,
I uploaded ArcGIS Pro to 3.5.x  but I cannot find the UNTools in the package Manager. Is the UNTools available for version 3.5.x?
Thanks
RobertKrisher
I just created a new clone using ArcGIS Pro 3.5.0. At first, the tools aren't visible:
Then I refreshed the metadata for my packages.
And then they appeared.
CodyPatterson
MVP Regular Contributor
Hey @SanchezNuñez
It appears that it is available: https://www.esri.com/arcgis-blog/?post_type=blog&p=2789102&preview=true
https://www.esri.com/arcgis-blog/products/utility-network/announcements/whats-new-utility-network-20...
I can find it here on my own Pro:
I would check to be sure you're in the Add Packages section, or check the Installed/Updates for potential updates!
Cody
RobertKrisher
Make sure you are using a cloned Conda environment and refresh your packages.
SanchezNuñez
Hi @RobertKrisher
See attached screenshot using cloned Conda.
SanchezNuñez
Found it!!
I just refreshed the exiting tolls and now the “untools” shows on the “Add Packages” list
RobertKrisher
STrimble
It would be nice that future versions do not require this.  I have upgraded several of my ArcGIS Pro 3.3 installs to ArcGIS Pro 3.5 and every clone has been removed.  After applying, untools are not searchable to add after recreating clone.  This process has never been stable since the inception of ArcGIS Pro and honestly these tools should be packaged as a core product of the ArcGIS Pro experience.  But regardless of solution, each release needs to have QA/QC and seems like many software companies are relying too much on automation and not the real user experience testing scripts because it requires resources.  In my opinion, many software solutions lack proper QA/QC.
