Unable to add junction object as controller when using a subtype group table
327
03-10-2026 01:44 AM
PierreloupDucroix
MVP Regular Contributor
In ArcGIS Pro, you can transform a junction object into a subnetwork controller by selecting a row in the xxxJunctionObject table and adding that selection to the "Edit Subnetwork Controller" panel.
However, I've found that this doesn't work when I select the row in the same table opened as a subtype group table. The panel doesn't seem to recognize the selection.
Has anyone else encountered this issue ?
ArcGIS pro 3.5, AGE 11.3
CEO of MAGIS
RobertKrisher
Open a case with support please.
