Re: Downstream Trace Crossing into Another Subnetwork and Failing with ERROR 001890
370
04-30-2026 04:24 AM
JohnGoat
Hi @RobertKrisher Some time has passed, and I was able to solve the issue with a different approach. I developed a script that automatically places a barrier whenever the trace reaches a Subnetwork Controller point. This script now works exactly as I wanted within the ArcGIS Pro interface.
import arcpy
import re
# URL
utility_network = "https://---/server/rest/services/Trace/FeatureServer/8"
# Starting Points  - FeatureServer/0
starting_points = "https://---/server/rest/services/Start_Points/FeatureServer/0"
# Barriers  - FeatureServer/1
barriers = "https://---/server/rest/services/Start_Points/FeatureServer/1"
# Electric Device (Subnetwork Controller) - FeatureServer/0
controller_fc = "https://---/server/rest/services/Trace/FeatureServer/0"
# CLEAR BARRIER
print("Clear Barrier")
with arcpy.da.UpdateCursor(barriers, ["OBJECTID"]) as cur:
    for row in cur:
        cur.deleteRow()
print("Barrier Cleared")
# GET STARTING POINT GUID
start_guid = None
with arcpy.da.SearchCursor(starting_points, ["FEATUREGLOBALID"]) as cur:
    for row in cur:
        start_guid = row[0]
        break
if not start_guid:
    raise Exception("No starting point found.")
print("Starting GUID :", start_guid)
# TRACE
def run_trace():
    arcpy.un.Trace(
        in_utility_network=utility_network,
        starting_points=starting_points,
        barriers=barriers,
        trace_config_name="{31407091-970B-4B14-BF68-F8C25B1349D6}",
        related_record_fields=None,
        result_fields=None
# GUID -> OBJECTID
def get_objectid_from_guid(guid_value):
    guid_clean = guid_value.replace("{", "").replace("}", "")
    where = f"GLOBALID = '{{{guid_clean}}}'"
    with arcpy.da.SearchCursor(controller_fc, ["OBJECTID"], where) as cur:
        for row in cur:
            return row[0]
    return None
# BARRIER INSERT
def insert_barrier(target_guid):
    oid = get_objectid_from_guid(target_guid)
    if oid is None:
        raise Exception("OBJECTID bulunamadi.")
    fields = [
        "FEATUREOID",
        "FEATUREGLOBALID",
        "LAYERID",
        "SOURCEID",
        "ASSETGROUPCODE",
        "ASSETTYPE",
        "TERMINALID",
        "PERCENTALONG",
        "ISFILTERBARRIER"
    values = [
        oid,
        target_guid,
        200,
        9,
        85,
        363,
        4,
        -1,
    with arcpy.da.InsertCursor(barriers, fields) as icur:
        icur.insertRow(values)
    print("Barrier added", target_guid)
try:
    print("The first trace is being tested...")
    run_trace()
    print("Trace successful.")
except arcpy.ExecuteError:
    msg = arcpy.GetMessages(2)
    print(msg)
    if "multiple subnetwork controllers" in msg.lower():
        guids = re.findall(r'\{[0-9A-Fa-f\-]{36}\}', msg)
        if len(guids) < 2:
            raise Exception("GUID not found.")
        start_guid_clean = "{" + str(start_guid).replace("{", "").replace("}", "") + "}"
        other_guid = None
        for g in guids:
            if g.upper() != start_guid_clean.upper():
                other_guid = g
                break
        if not other_guid:
            raise Exception(" controller GUID not found.")
        print("Barrier adding:", other_guid)
        insert_barrier(other_guid)
        print("Trace is working again...")
        run_trace()
        print("Trace successful")
    else:
        raise Exception("Unexpected Trace error: " + str(msg))
print("\n=== TRANSACTION COMPLETE ===")
I would like to ask for guidance about a Utility Network trace automation workflow.
  1. A user places a starting point on the map.
  2. The script runs a Trace operation.
  3. If the trace returns the following error:
ERROR 001890: Invalid subnetwork connectivity, multiple subnetwork controllers with different subnetwork names found.
  1. The script reads the error message and extracts the two GlobalIDs listed in the message.
  2. It compares them with the starting point GlobalID.
  3. It automatically creates a barrier point on the other GlobalID (not the starting point).
  4. The same trace is executed again.
  5. On the second run, the trace completes successfully without error.
So overall, the script acts as an automatic workaround for controller conflicts and it runs correctly inside ArcGIS Pro.
My Problem
I now want to publish this script as a Geoprocessing Tool / Share as Web Tool so I can use it inside Experience Builder.
However, during publishing I receive this error:
at the server version 11.5 the related record fields parameters position in the parameter set has changed
According to Esri documentation, related_record_fields is not a required parameter. I still explicitly added that parameter in the script, but the publishing error remains.
My Goal
My final goal is to run this custom trace logic inside Experience Builder through a Geoprocessing widget.
 My Questions
  1. Is publishing a Python script with arcpy.un.Trace() as a Web Tool the correct architecture for this scenario?
  2. Is there a better approach for Experience Builder (for example calling the Utility Network REST trace endpoint directly)?
  3. Has anyone seen this publishing error with ArcGIS Enterprise 11.5 and Utility Network trace tools?
Any guidance would be greatly appreciated.
gis_KIWI4
MVP Regular Contributor
@JohnGoat- Unless you need some python-only processing a better long term solution is to create a custom trace widget in ExB. While python approach is simpler to develop, if you want your users to use it you have to account for authentication, context and handling outputs. Python scripts work well in ArcGIS Pro but in the context of web maps they are slightly harder to implement.
example - Web map interaction isn't straight forward, you cannot send a selection directly as a starting point/barrier in the python script but you can with a custom ExB Widget.
While I don't know the in's and out's of your scenario, I can't help but wonder if a named trace configuration would work?
If your trace config is a downstream or upstream (or any subnetwork based trace) then it's going to be bound by the Subnetwork.
What I mean to say is that the Traversibility Filters for your trace should look the same as your Subnetwork.
Are you expecting to trace "downstream" or "upstream" into another subnetwork?
gis_KIWI4
