Migrate to utility network and Apply error resolution
1750
8
03-25-2025 12:13 AM
Davis_Dad23
Hello
I have met issue with new migration tools.
I have successfully migrated source database to UN model and i have also used analyze network data tool to produce all errors generated successfully.
But the issue i have now, is on the apply error resolution tool that uses the error resolution table that was generated from the analyze network data if i not wrong.
I am running this apply error resolution tool but it is running successfully but the folder still is empty neither having no any change on the UN model migrated with errors.
What is the best way to use this tool and what do you think that i might be missing to run the apply error resolution successfully.
Please help me to find out how the best way to use this tools successfully and resolve the generated errors
@RobertKrisher
RobertKrisher
To resolve errors, you must review the Analysis Results database and provide resolutions to each error you want to fix. Applying default resolutions will only solve some of the errors.
Read these articles for more instructions on how to use the tools:
If you are still unable to resolve errors after following the process outlined in those articles, reach out again.
MikeMillerGIS
Esri Frequent Contributor
Could you share your error resolution table with us?  We would like to see what resolutions are provided.  Are there any messages in the GP messages?  Are log files created in the output folder?
RobertKrisher
samshrma998
I have been encountering same issue. For me I am getting a warning message ang log file saying "an edit operation is required".
I am running the tool to correct stacked points and have error resolution defined as "Delete all but first".
Surprisingly , the tool work as expected on AGP 3.5.1 but gives warning in AGP 3.5.5 (attached screenshot).
Further, when I add and use the standalone toolbox which I have been using in past during AGP 3.3, it works well in AGP 3.5.5 also.
Is there any additional things to consider while using this tool on 3.5.5.
RobertKrisher
Please log an issue with support for this to get a bug created so you can be notified when we release the patch that correct it.
streamside
Has the issue been reported.  I am having similar issues.  The tool ran a couple time in 3.5 with 'Create' action on missing junctions.  Upgrade to 3.6 and the tools says it run successfully but there is no output....no logs, no table showing Inserts Updates and Deletes.
RobertKrisher
There is currently a known issue where the tool can fail to run and produce an error, but there aren't any issues I'm aware of where the tool silently fails. Please log an issue with support so we can understand what is happening.
samshrma998
*I had logged support case and got a BUG logged for this. Though bug is not
made public yet.*
*BUG-000181823: In ArcGIS Pro, 'Apply Error Resolution' tool fails to apply
edits to the features, but executes with a warning "WARNING 004202: Some
edits failed*
RobertKrisher
@samshrma998  @streamside . If you receive a warning when applying the edits, then it's a known issue (BUG-000181823). If the tool doesn't report any warnings or errors, but no resolutions are applied, then that is not something we are aware of, and you will want to log an issue, so support can investigate what is happening.
