Inconsistent trace results
9570
11
11-23-2022 06:53 AM
Jens_Dalsgaard
I experience inexplicable and inconsistent downstream trace results. I have really tried myself understanding what is going on - I do not get it though.
From a high voltage substation (HV/MV) I set a trace start flag on the secondary winding on one of the transformers and request a downstream trace - se screen dump below:
As the trace is set to continue into low voltage (target tier), of course I would expect the trace to do so. In the below screen dump, you see that it does not continue into the low voltage mesh (blue lines):
And zooming into a medium voltage substation (MV/LV) it is clear that the trace stops at the MV/LV transformer - se screen shot below:
Really strange, cause I have successfully run an update subnetworks on the low voltage mesh, so I know that the trace from this transformer and downstream should work.
Now, moving the trace start point (from the HV/MV transformer secondary) to just outside this substation and running the exact same trace I reach this inconsistent result that you see below - the trace continuing through the MV/LV transformer and into the low voltage mesh as configured in the GP:
Enlighten me please, Esri (or someone else). I cannot see me doing anything wrong here - I might though. Or UN might have a bug?
One thing is for sure - you have a puzzled user.
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
emin-saka
Hi all,
I am happy to inform you that the BUG-000148077 was fixed with the new version of ArcGIS Enterprise/Pro (11.2 / ArcGIS Pro 3.2)
BUG-000148077 : "The downstream trace across tiers does not reach the target tier in some cases."
Jens_Dalsgaard
Given the fact that the consolidation version for Utility Network is ArcGIS Pro 3.1 could you inform me please on when we may expect a 3.1 patch with this fix.
Jens Dalsgaard
volue.com
