Field maps with Utility Network
1799
09-28-2023 12:06 AM
ShamsMoaied
Hello
I have a question, Does Field maps support the Utility Network?
According to this article What’s new in ArcGIS Field Maps (June 2022) (esri.com) the UN is supported since ArcGIS Enterprise 10.9.1+. I'm using the ArcGIS Enterprise 11 but when I opened the web map (that contains the utility and subtype group layers) it does not work and seems that it does not support the subtype group layer.
Any advice?
Tags (4)
RichardKoch
Shams,
I would start with this article.
ArcGIS Utility Network and ArcGIS Field Maps (esri.com)
From there it has links at the bottom to some of the other pages and information you need to fill in the answers to the questions you have.
biggest thing is to read and learn about all your options, so you build a sustainable workflow for your team. Any time spent by you and your team learning will be paid back 100 times over by an efficient and enabled field workforce.
Best to you and happy learning and planning.
Richard Koch
ShamsMoaied
Hi again,
According to this articles
Work with utility networks—ArcGIS Field Maps | Documentation
The subtype group layer is supported in Field Maps, but the same error still appeared. However, all the requirements are met
