Export Subnetwork: Including indirectly associated structure elements
188
07-02-2026 06:57 AM
NikoszMavridisz
 We would like to use the Export Subnetwork tool as part of a data integration workflow. Our use case requires exporting all associated structures, not only the structures that directly support the subnetwork. For example, StructureJunctionObjects contained by a supporting StructureJunction feature are excluded. Is there any recommended approach to include these indirectly associated objects in the exported JSON, or is the only option to add them in a post-processing step?
Thank you!
RobertKrisher
Currently the only way to do this is through a post-processing step, but if you log a case with support there is an existing enhancement you can help escalate: ENH-000126146
RobertKrisher
