Error running Create Utility Network Associations tool
1357
12-26-2024 01:36 PM
Isaac_King
I am encountering a new error when attempting to create associations in an asset package and hoping y'all might have some insight.
Conditions:
  • ArcGIS Pro 3.3.2
  • UNtools 3.3.3
  • UNv7 (electric)
I have previously run this process successfully in a different instance of this asset package. I am using a new install of Pro as I am using a different machine now.
I am encountering the following error:
A python error occurred.
EXCEPTION
  File "C:\Users\xyzx\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\common\wrappers.py", line 161, in wrapper
    f = func(*args, **kwargs)
  File "C:\Users\xyzx\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\untools\gptools\tools.py", line 476, in run
    sources = len(a.un.describe.domain_networks[1:]) * 4 + 3
AttributeError: 'UtilityNetwork' object has no attribute 'describe'
pleh
Isaac_King
I've now tested this against the asset package included in the Electric Foundation Package and encountered the same error - so at least it's not an issue with my AP!
PaulLeBlanc1
It is a bug with untools -- no asset package will work.
Apologies for that, I've uploaded the very simple fix to anaconda -- untools 3.3.3.1. It only has this fix, hence the additional patch number.
