ERROR 000581: Invalid parameters. Failed script Apply Asset Package; Stopped at UtilityNetwork_1_Tiers.xml
70
yesterday
Rohanrajan
I am trying to Apply Asset Package and I get this error.
Asset Package schema version: 3.4 Staging directory -- Path\AP_Workspace
Path\AP_Workspace\xml\UtilityNetwork_1_Tiers.xml:3
ERROR 000581: Invalid parameters. Failed script Apply Asset Package... Failed to execute (AssetPackageToUtilityNetwork).
<operationSequence>
<workflow>
<ModifyNetworkProperty>
<modify_type>add</modify_type>
<key>HasClusterKey</key>
<value>0</value>
</ModifyNetworkProperty>
</workflow>
<workflow>
<AddTierGroup>
<domain_network>Water</domain_network>
<name>Water System</name>
</AddTierGroup>
</workflow>
<workflow>
<AddTier>
<name>Raw Water Distribution</name>
<rank>1</rank>
<topology_type>MESH</topology_type>
<tier_group_name>Water System</tier_group_name>
<subnetwork_field_name>RWSSubnetworkname</subnetwork_field_name>
</AddTier>
<AddTier>
<name>PBSystem</name>
<rank>2</rank>
<subnetwork_field_name>PBSubnetworkSystemname</subnetwork_field_name>
</AddTier>
<AddTier>
<name>Pressure Boundary</name>
<rank>2</rank>
<subnetwork_field_name>PBSubnetworkname</subnetwork_field_name>
</AddTier>
</workflow>
</operationSequence>
If anyone could point us to the error, it would be much helpful
Thanks in advance
MikeMillerGIS
Esri Frequent Contributor
What version of ArcGIS Pro?  I see Cluster Key as a property set, try removing that from the A_PropertySet table in the asset package.
