Edit Operation Failed - Error
821
01-08-2026 09:09 AM
Joshua_Moreno
Hello,
Not sure what has caused this, when I edit vertices/create new features in my UN service within arcgis pro, I keep getting errors that force me to reapply the change at least 3 times before it actually works.
All I'm doing it creating new features or editing vertices against the UN service. It seems like I have to wait a little while before making my next change in between edits, I assume as it writes the changes to the service in Portal. Can something be causing this? My UN is only about 15,000 features including lines and points, not large at all and it's hosted in it's own enterprise GDB.
Joshua_Moreno_0-1767891942490.png Edit Operation Failed - Other Error I keep getting along with this screenshot.
RobertKrisher
If you haven't already, please log a case with support on this. What are the pooling settings on the service you're using to edit the utility network? Here's an example of the default settings, which should probably be increased when the service is being used in a production capacity.
Joshua_Moreno
I'm at 4 and 8 instances for min and max. I'll submit a ticket, thank you!
RobertKrisher
If you check the server logs you should be able to see some warnings or an error that gives you more detail as to what is going wrong.
