edit operation failed. ERROR: The table was not found
2984
04-20-2021 04:54 PM
DaniellaSollitt
I was validating the network and this error showed up.
What does it mean?
by Anonymous User
Not applicable
This is another one of these random validate network topo failing with a cryptic message.  There will be nothing in server logs to try and track this down.  I'd suggest submitting a ticket to support even if you get it working.  They are using our tickets like these to hopefully make things better for future releases.   I will say 10.8.1 and Pro 2.7 are much better than 10.6 and 10.7 and we've seen less of these errors and the ability to recover from these errors improve.
DanPatterson
Are you using the tool in ArcToolbox?
... sort of retired...
DaniellaSollitt
No, just in the Utility Network Data tab
DanPatterson
do you get the same message with the tool?
you might get a better message if there is an error or incomplete step in the process
by Anonymous User
Not applicable
