Do features need to be M-enabled for Utility Network compatibility?
3591
6
01-30-2023 10:11 AM
AaronManuel2
I am trying to figure out if features participating in a utility network need to be m-enabled as a prerequisite, and I can't seem to find the answer to this in the documentation.
I'm working on setting up some water utility features for utility network capability sometime in the future. They are z-enabled but not m-enabled. We are interested in things like network diagrams and modeling DMA's.
Does this require M values?
Thank you
MikeMillerGIS
Esri Frequent Contributor
M's are enabled by default and you cannot disable them.  You do not have to fill them out.
Jens_Dalsgaard
Have experience in electric utility and UN only. Yet, I am quite sure, that m-enablement is NOT needed.
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
AaronManuel2
Thank you, so in your utility network, do you have participating features that do not have m enabled? Are you still able to do things like network trace?
Jens_Dalsgaard
According to Mike, classes must be m-enabled.
But you don't have to do anything with the m-enablement. At least, we don't, and still it works like a beauty.
Maybe, we'll end up using the m-enablement further down the line, but for a start we don't.
Jens Dalsgaard
volue.com
MikeMillerGIS
AaronManuel2
Thank you. But when I create new features in pro, Z values are checked automatically but Ms are not. The features I'm working with do not have M values. The dataset does have an M resolution/tolerance. So when you say they are enabled by default I'm a little confused. Do you mean on the dataset itself?
JimmyBowden
As Mike indicated the Utility Network feature classes are M enabled when they are created.  If you are deploying your UN as an enterprise you will want to check the box "Allow geometry updates without m-value" in the Feature properties.  This will set the M value to NaN when features are created. At this point you can just ignore them.
