Display UN trace result features only
1798
01-06-2023 03:35 AM
DasheEbra
Hi folks, I work with Electric utility network, and I want to display only the Trace result features. I know that definition query can do that, but as we know there are much layers and I want a quick way for that.
AyanPalit
@DasheEbra Where do you want to display the trace results? ArcGIS Pro, web app, dashboard? Are there other requirements other than mere visualization?
Ayan Palit | Principal Consultant Esri
DasheEbra
ArcGIS Pro 2.9 with Enterprise 10.9.1
jclarke
If you are using Pro, you could take a look at the "Aggregated Geometry" result type - this will create new map layers for the results, so you can display just those layers.
DasheEbra
Thanks dear, it's a good solution. But the new layers appeared with no subtype groups Is there a way to display theme with subtype groups (Asset group) same as the original layers?
jclarke
