Descriptions in Utility Network Data Dictionary
1633
07-21-2023 08:14 AM
lorenzoz
I'm posting this because I'm trying to implement the Water Utility Network Foundation.
I found some issues in understanding how some parts of the network link to each other, because the Utility Network Data Dictionary lacks in some descriptions. For example, for the Water Devices, assetgroup Service Valve, there are no descriptions, even if I click on the assettypes (image below).
Will the data dictionary be updated? Is there a way to find more descriptions?
This is just an example. I found the same issues also with the Gas and Pipeline Utility Network Foundation.
Any advice is appreciated.
Thank you,
Lorenzo
MikeMillerGIS
Esri Frequent Contributor
There is an issue with the Service Explorer, where it is not loading descriptions when navigating to the Subtype via the contains pane.  If you navigate to it via the Subtypes link, it loads the descriptions:
MikeMillerGIS
