D_Configuration and schema changes
1136
01-18-2024 11:42 PM
Jens_Dalsgaard
A quick question.
I have a schema and a corresponding D_Configuration (XYZ) working as intended.
Now I add e.g. an extra attribute (ABC) to one of the feature classes in the asset package template and migrate data thereto.
What would happen if after adding this attribute ABC I apply the asset package with the D_Configuration XYZ without updating this D_Configuration with this new attribute ABC?
Will attribute ABC be filtered out and not be applied to the utility network, or not?
Best regards
Jens Dalsgaard
Principal Product Owner
Power Grid, V O L U E
jens.dalsgaard&@volue.com
Volue Technology Denmark A/S
Alfred Nobels Vej 27
9220 Aalborg Øst, Denmark
volue.com
MikeMillerGIS
Esri Frequent Contributor
A value/entry not listed in the D_ tables is always applied to the target.
MikeMillerGIS
