Create Network Diagram for Diverse Paths
1301
02-25-2021 04:44 PM
by Anonymous User
Not applicable
Hi All,
I have a water utility network setup in an enterprise geodatabase.
I would like to know if it is possible to combine the output of 2 traces into a single diagram.
For instance, I am running a shortest pat trace between 2 points in the network. The first trace finds the shortest path and I create a network diagram from that selection. I then add those selected features as barriers for a second shortest path trace that I run so I can find an alternative "diverse" path in the network. I create a network diagram from that trace.
Now I would like to combine those 2 outputs into a single diagram, or have some mechanism to run the 2 traces and select all features to create a single unified diagram.
Does anyone know if this is possible?
Many thanks.
PaulLeBlanc1
The various selection options on the Trace GP tool should do the trick (the default is new selection):
by Anonymous User
Not applicable
Hey Paul,
That worked a treat. Thanks for the suggestion.
by Anonymous User
Not applicable
HI @Anonymous User ,
Did you want this to still go into a diagram ( such as the network diagram)  or was the tracing sufficient?
