Apply Asset Package will not apply some attribute rules
1626
6
11-06-2024 10:12 PM
PierreloupDucroix
MVP Regular Contributor
Hello @MikeMillerGIS
When applying an asset package to Postgres 14 Enterprise 11.3, I noticed that some of my attribute rules did not apply while others did.
Only Constraint rules seems concerned in my case
Here is a sample code of a constraint rule that did apply (intended to check if a certain field has unique value if not null) :
if($feature.NDB == null){
  return True
else{
  var concession = $feature.CONCESSI;
  var gid = $feature.GLOBALID
  var fsBrt = Filter(FeatureSetByName($datastore, "ElectricDevice", ["GLOBALID", "ASSETGROUP", "NDB", "NSRNDB"], False), "ASSETGROUP = 10 AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
  var uniqueIds = [];
  var i = 0;
  for (var brt in fsBrt) {
    if (brt.NDB != null){
      uniqueIds[i++] = brt.NSRNDB
  var calcNsrNdb = concatenate($feature.NSR,'/',$feature.NDB)
  if (Includes(uniqueIds, calcNsrNdb)){
    return False
  else{
    return True
And a very similar Constraint rule that will not apply :
if ($feature.NUMERO == null){
  return True
else{
  var assetGroup = $feature.ASSETGROUP
  var uniqueIds = [];
  var i = 0;
  var table = "ElectricJunction"
  if (Includes([11, 12, 13, 15, 16], assetGroup)){
    table = "ElectricDevice"
  if (Includes([16, 33], assetGroup)){
    var HtaNoeudfeatureDataset = Filter(FeatureSetByName($datastore, "ElectricJunction", ["GLOBALID", "NUMERO", "SIG_ID_UNIQUE"], False), "ASSETGROUP = 33 AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
    var HtaInterfeatureDataset = Filter(FeatureSetByName($datastore, "ElectricDevice", ["GLOBALID", "NUMERO", "SIG_ID_UNIQUE"], False), "ASSETGROUP = 16 AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
    for (var feature in HtaNoeudfeatureDataset) {
      if (feature.NUMERO != null){
        uniqueIds[i++] = feature.SIG_ID_UNIQUE
    for (var feature in HtaInterfeatureDataset) {
  else{
    var featureDataset = Filter(FeatureSetByName($datastore, table, ["GLOBALID", "NUMERO", "SIG_ID_UNIQUE"], False), "ASSETGROUP = @assetGroup AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
    for (var feature in featureDataset) {
  if (Includes(uniqueIds, $feature.SIG_ID_UNIQUE)){
    return False
  else{
    return True
I guess it may be related to the "table" variable used to manage the table used in the featureSetByName function. In general, Apply Asset Package will add geodatabase name as a prefix, like "my_gdb.ElectricJunction" but in this case it fails without any error. Apply Asset Package will end normally, but the rule will not apply.
Do you have any idea how to resolve this ?
CEO of MAGIS
MikeMillerGIS
Esri Frequent Contributor
In the ap_workspace folder, is there any reported in the GP log?  Can you verify the AR is in the xml file in the apworkspace folder?
PierreloupDucroix
Here is the log regarding the AR in the log file :
arcpy.gp.UpdateSchema(
"D:\\....myfolder.....\\myNetwork\\ElectricDevice",
"D:\\arcgispro\\creation_geodatabase\\AP_Workspace4\\xml\\ElectricDevice_2_EditorTracking-AttributeRules.xml",
EnableEditorTracking 1
AddAttributeRule 40
--> I have 44 AR in this feature class and in the Asset Package. 4 are missing and correspond to the code I sent you.
But yes, you can see here that the AR is in the AP_UN.xml file :
CEO of MAGIS
MikeMillerGIS
If they are in the file, we are sending them to the GDB. If the gdb is failing to add them and not report an error, that is an issue.  Any chance we can get the entire AP Workspace?
PierreloupDucroix
I just sent it to you by mail.
Regards
CEO of MAGIS
PierreloupDucroix
Hi @MikeMillerGIS
I finally turn this :
var table = "main.ElectricJunction"
  table = "main.ElectricDevice"
into this :
      var featureDataset = Filter(FeatureSetByName($datastore, "main.ElectricJunction", ["GLOBALID", "NUMERO", "SIG_ID_UNIQUE"], False), "ASSETGROUP = @assetGroup AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
    else{
      var featureDataset = Filter(FeatureSetByName($datastore, "main.ElectricDevice", ["GLOBALID", "NUMERO", "SIG_ID_UNIQUE"], False), "ASSETGROUP = @assetGroup AND CONCESSI = @concession AND GLOBALID <> @gid AND CYCLEVIE NOT IN (4,7)");
It is now working fine, but not sure why it was not importing with the asset package but working once applied on the UN table
CEO of MAGIS
MikeMillerGIS
Sorry, I must have missed your mail, been a busy few weeks.  I will try to look at it and see why the import was dropping it.
