Great stuff and hopefully this can be done via the diagrams capabilities.
Hi @RobertThomson and @ScottFierro1,
Indeed, we can imagine to generate a network diagram to visualize how the utility network is structured.
NOTE: Such a function can be provided as an ArcGIS Pro add-in command that generates the diagram#B in one click. You can also expose the custom layout algorithm in the Layout gallery so users can manually apply the layout to the active diagram (#A => #B)
