Create Migration Workspace global mappings
421
03-09-2026 09:03 AM
Status: Open
Joshua-Young
MVP Regular Contributor
Many of our existing feature classes from the Esri Local Government Information Model use the same field names and coded domain values. The Create Migration Workspace script created 159 Excel spreadsheets for our migration to a Water Utility Network. Many of those spreadsheets require very similar if not the exact same field and domain mappings.
It would save a lot of time if there was a way do the field and domain mapping once and have it applied to each spreadsheet when the Create Migration Workspace script is run.
Manually opening up each spreadsheet to copy the field mappings is not too time consuming, but setting up the same domain mappings over and over again takes a lot more time.
1 Comment
RobertKrisher
This is already possible via match tables and global lookups in the Data Loading toolset.
