Utility Network Package toolbox 3.5 release notes
1696
06-06-2025 08:30 AM
The 3.5 release of untools contains the fixes from untools 3.4.0 and 3.3.4. For more information, see the 3.3 release notes.
untools 3.5.1 - August 2025
  • Apply Asset Package
    • Support Enable/Calculate ClusterKeys -- this is controlled by the "HasClusterKey" entry in the A_PropertySet table
    • Better support for older utility network versions
      • Historically, the asset package could only be applied to current utility network release for a specific ArcGIS Pro version. This has been relaxed across releases, but untools internally modeled the utility network as the latest release and did not take into consideration the target utility network version. Now, it will skip applying certain properties (e.g. FlowDirection fields, ClusterKeys) if the target utility network does not support it.
untools 3.5.0 - May 2025
    • Support multiple subtypes in attribute rules
    • Increase field lengths to 128
  • Stage Utility Network
    • Use new parameter from Create Utility Network to control UN version (previously it wrote to the registry)
Version history
Last update:
‎09-24-2025 07:14 AM
Updated by:
Contributors
