Utility Network Package toolbox 3.2 release notes
3064
11-11-2023 07:50 AM
The 3.2 release of untools contains the fixes from untools 3.1.1. For more information, see the 3.1 release notes.
untools 3.2.0 - November 2023
  • Apply Asset Package
    • Support new field types
    • Validate multiple propagators assigned to the same field
    • Support system network attributes in subnetwork definition
    • Support user domains assigned to the TerminalConfiguration field.
  • Asset Package to Geodatabase
    • Change default Workspace Type to Mobile Geodatabase
  • Implementation details
    • untools is now build with the latest conda format, which provides smaller sizes and faster install times
    • The geoprocessing toolbox has moved from a pyt to an atbx
Comments
MennoTerBals_GIS4C
Good morning,
I'm trying to install the untools package but can't find it.
I'm on ArcGIS Pro 3.2.1, advanced license, and I cloned the default conda environment and activated the new environment. Yet the untools package does not show up under Add Packages.
The refresh button is also missing in the package manager.
Am I overlooking something?
Any advice will be welcome.
Cheers,
Menno
PatrickGCowan
The refresh button has been moved. Click the "environment manager" button (looks like a cog) next to your active environment.
Select the environment you want to update and press the refresh button:
Check for the untools again after you perform the refresh.
MennoTerBals_GIS4C
Thanks @PatrickGCowan! That worked.
I need to search better next time...
Version history
Last update:
‎11-11-2023 07:50 AM
Updated by:
Contributors
