Utility Network Package toolbox 3.1 release notes
3437
02-27-2023 06:05 AM
The 3.1 release of untools contains all of the patches from untools 2.9.1 - 2.9.5. For more information, see the 2.9 release notes.
untools 3.1.2 - July 2024
  • Apply Asset Package
    • Expose options (untools.common.settings) for custom precision/scale on single/double fields
    • Resolved issue where standalone tables would not be created in the target workspace
  • Export Asset Package
    • Skip updating HANA workspace to branch
    • Reset invalid attribute rule category values
    • Support very large XML workspace documents
untools 3.1.1 - August 2023
    • Handle renaming elements that share names (eg Feature Dataset and Feature Class)
    • Fix for incorrect validation on condition barriers comparing two network attributes
    • Resolve issue where the incorrect CSV delimiter was used for associations / controllers
  • Change Asset Package Spatial Reference
    • Support geodatabase with LRS
  • Asset Package Schema
    • Change field lengths of various tables to match information model restrictions.
untools 3.1.0 - February 2023
    • Support configuring more than one propagator per tier.
    • Do not error when creating sequences that already exist in the target workspace.
    • Validate subnetworks that start and end with a colon.
    • Validate that subnetwork summary fields are not reused per tier.
    • Add support for configuring paths on configurations with 2 terminals.
    • Validate terminal paths that are named "Default".
    • Resolved BUG-000154874, which was giving an incorrect error message for subnetwork controller validation.
    • Remove more invalid whitespace characters from XML.
    • Resolved issues where an incorrect GUID field was being converted to GlobalID.
  • Asset Package schema
    • B_AttributeRules table, changed the category field from string to short.
    • Asset Package schema version is now 3.1.
  • D_Configuration table
    • Added state 5: Keep when applied
    • Added state 6: Always keep when applied
Version history
Last update:
‎07-10-2024 06:18 PM
Updated by:
