Branch Version Sql Views - Utility Network
19079
18
08-09-2022 07:50 AM
The following queries show examples of how to create materialized views on branch versioned utility network for various DBMS. For additional information about the reasoning behind this approach, please refer to the Branch Versioning and SQL Esri blog post.
PostgreSQL
Create Materialized Views
DROP MATERIALIZED VIEW IF EXISTS unadmin.device_bvw;
CREATE MATERIALIZED VIEW unadmin.device_bvw
AS
	WITH t0_ AS
		(SELECT objectid, globalid, assetgroup, assettype, assetid, shape
		FROM
			(SELECT  objectid, globalid, assetgroup, assettype, assetid, shape, Row_number() over (PARTITION BY objectid ORDER BY gdb_from_date DESC) rn_, gdb_is_delete
			FROM     unadmin.electricdevice
			WHERE    (gdb_branch_id = 0)) a
WHERE rn_ = 1
AND gdb_is_delete = 0 )
	FROM     t0_
WITH DATA;
CREATE UNIQUE INDEX IF NOT EXISTS device_bvw_uuid
    ON unadmin.device_bvw USING btree
    (globalid COLLATE pg_catalog."default" ASC NULLS LAST)
    TABLESPACE pg_default;
CREATE INDEX IF NOT EXISTS device_bvw_spat_idx
    ON unadmin.device_bvw USING gist
    (shape)
Refresh Views
Once you’ve created the materialized view(s), you should create and schedule a function in your database to refresh them periodically. How often you call this function and refresh your views depend on the volume of edits you make and how long it takes to refresh the views. A common practice is to refresh the views once or twice a day, but for very large datasets or datasets that require a lot of additional processing you may only refresh the views once a week.
CREATE OR REPLACE FUNCTION
unadmin.refresh_bvw()
RETURNS VOID
LANGUAGE 'plpgsql'
AS $$
DECLARE
BEGIN
	REFRESH MATERIALIZED VIEW unadmin.assembly_bvw;
	REFRESH MATERIALIZED VIEW unadmin.device_bvw;
	REFRESH MATERIALIZED VIEW unadmin.junction_bvw;
	REFRESH MATERIALIZED VIEW unadmin.line_bvw;
	REFRESH MATERIALIZED VIEW unadmin.structureboundary_bvw;
	REFRESH MATERIALIZED VIEW unadmin.structurejunction_bvw;
	REFRESH MATERIALIZED VIEW unadmin.structureline_bvw;
	REFRESH MATERIALIZED VIEW unadmin.associations_bvw;
	REFRESH MATERIALIZED VIEW unadmin.subnetworks_bvw;
END;$$
ALTER FUNCTION unadmin.refresh_bvw()
    OWNER TO unadmin;
Oracle
You should consult with a DBA before specifying any parameters in your create index statement, otherwise the defaults for the database are used.
If you include a geometry in your view you need to specify the spatial grid size and spatial reference id (SRID) of the base table when creating the spatial index on the shape field. In the example below I have included a statement that you can use to query this information.
GRANT CREATE MATERIALIZED VIEW TO UNADMIN;
CREATE MATERIALIZED VIEW DEVICE_BVW
BUILD IMMEDIATE
REFRESH COMPLETE
ON DEMAND
AS
SELECT OBJECTID, GLOBALID, ASSETGROUP, ASSETTYPE, ASSETID, SHAPE
FROM UNADMIN.ELECTRICDEVICE
WHERE GDB_ARCHIVE_OID IN
	(SELECT GDB_ARCHIVE_OID
	FROM
		(SELECT GDB_ARCHIVE_OID, ROW_NUMBER() OVER(PARTITION BY objectid ORDER BY gdb_from_date DESC) rn, gdb_is_delete
		WHERE (gdb_branch_id = 0)) br__
	WHERE br__.rn = 1
	AND br__.gdb_is_delete = 0);
CREATE UNIQUE INDEX DEVICE_BVW_UUID ON DEVICE_BVW (GLOBALID) ;
--Get the underlying grid size and SRID from the base table
SELECT A.GRID.GRID1, A.GRID.GRID2, A.GRID.GRID3,A.SRID
FROM SDE.ST_GEOMETRY_INDEX
WHERE OWNER = 'UNADMIN' AND TABLE_NAME = 'ELECTRICDEVICE';
--Create a spatial index
CREATE INDEX DEVICE_BVW_SA_IDX
 ON UNADMIN.DEVICE_BVW  (“SHAPE”)
 INDEXTYPE IS sde.st_spatial_index
 PARAMETERS('st_grids=<Grid Sizes Here> st_srid=<Your ID Here>');
Refresh Views
To keep your views up to date, you should create a materialized view refresh group for these views and set it to execute on a regular schedule to ensure the data is refreshed often enough to meet your reporting requirements but not so often it places a burden on your system. You can learn more about refresh groups by reading Oracle’s online help for DBMS Refresh.
Oracle 21C and later have methods for automatically refreshing materialized views. However, if you are using an older release of oracle you will want to schedule a refresh group that handles refreshing your materialized views.
BEGIN
   DBMS_REFRESH.make(
     name                 => 'UNADMIN.BVW_REFRESH',
     list                 => '',
     next_date            => SYSDATE,
     interval             => '/*12:Hours*/ SYSDATE + 12/24',
     implicit_destroy     => FALSE,
     lax                  => FALSE,
     job                  => 0,
     rollback_seg         => NULL,
     push_deferred_rpc    => TRUE,
     refresh_after_errors => TRUE,
     purge_option         => NULL,
     parallelism          => NULL,
     heap_size            => NULL);
END;
BEGIN
   DBMS_REFRESH.add(
     list => 'UNADMIN.ASSEMBLY_BVW,UNADMIN.DEVICE_BVW,UNADMIN.JUNCTION_BVW,UNADMIN.STRUCTUREBOUNDARY_BVW,UNADMIN.STRUCTUREJUNCTION_BVWUNADMIN.STRUCTURELINE_BVW',
     lax  => TRUE);
END;
Sql Server
Create Reporting Table
Even though SQL Server does have an implementation for materialized views (called indexed views) it is recommended that you do not use indexed views to materialize the results of queries. You can read more about these restrictions in Microsoft’s online help. Instead, you should write a stored procedure that will recreate tables and indices for your queries.
The following statement to create a stored procedure that will create or refresh a reporting table for electric devices in the utility network for a SQL server database. Because we are doing this all in a single stored procedure, we also include the statements for creating the indices.
CREATE OR ALTER PROCEDURE [unadmin].[CreateDevice_BVW]
AS BEGIN
BEGIN TRY
  BEGIN TRANSACTION
  /* DECLARE PROCEDURE VARIABLES */
  DECLARE @minx            NUMERIC(38,8);
  DECLARE @miny            NUMERIC(38,8);
  DECLARE @maxx            NUMERIC(38,8);
  DECLARE @maxy            NUMERIC(38,8);
  DECLARE @ErrorMessage    NVARCHAR(4000),
          @ErrorNumber     INT,
          @ErrorSeverity   INT,
          @ErrorState      INT,
          @ErrorLine       INT,
          @ErrorProcedure  NVARCHAR(200);
  /* DROP THE TABLE IF ALREADY EXISTS */
  DROP TABLE IF EXISTS [unadmin].[Device_BVW];
  /* CREATE THE TABLE BASED FROM DEFAULT RECORDS OF THE BRANCH VERSIONED TABLE */
  SELECT OBJECTID, GlobalID, Shape
  INTO [unadmin].[Device_BVW]
  FROM [unadmin].[Device]
  WHERE GDB_ARCHIVE_OID IN (
    FROM (
      SELECT GDB_ARCHIVE_OID, ROW_NUMBER() OVER(PARTITION BY OBJECTID ORDER BY GDB_FROM_DATE DESC) rn, GDB_IS_DELETE
      FROM [unadmin].[ Device]
    WHERE br__.rn = 1
    AND br__.GDB_IS_DELETE = 0);
  /* ADD INDEXES */
  ALTER TABLE [unadmin].[Device_BVW]
  ADD CONSTRAINT [Device_BVW_pk] PRIMARY KEY CLUSTERED ([OBJECTID] ASC);
  CREATE UNIQUE NONCLUSTERED INDEX [DEVICE_BVW_UUID]
  ON [unadmin].[Device_BVW] ([GLOBALID] ASC);
  --You only need to do this if your resulting table needs a shape column.
  --This will construct a spatial index using the extent of the original table
  WITH
    envelope AS  (SELECT shape.STEnvelope() AS envelope FROM [unadmin].[ Device]),
    corners AS  (SELECT envelope.STPointN(1) AS point FROM envelope
                 UNION ALL SELECT envelope.STPointN(3) FROM envelope)
  SELECT @minx=min(point.STX), @miny=min(point.STY), @maxx=max(point.STX), @maxy=max(point.STY) FROM corners;
  /* GENERATE & EXECUTE THE SQL FOR CREATING THE SPATIAL INDEX */
  DECLARE @sql NVARCHAR(2000) = 'CREATE SPATIAL INDEX [Device_BVW_spidx] ON [unadmin].[ Device_BVW] (Shape)
                                 USING GEOMETRY_AUTO_GRID WITH (BOUNDING_BOX =('+CAST(@minx AS NVARCHAR(20))+','
        +CAST(@miny AS NVARCHAR(20))+','
        +CAST(@maxx AS NVARCHAR(20))+','
        +CAST(@maxy AS NVARCHAR(20))+'))';
  EXECUTE (@sql);
  COMMIT TRANSACTION
END TRY
BEGIN CATCH
  /* IF ERROR THEN ROLLBACK TRANSACTION AND RETURN ERROR */
  SELECT @ErrorNumber = ERROR_NUMBER(),
         @ErrorSeverity = ERROR_SEVERITY(),
         @ErrorState = ERROR_STATE(),
         @ErrorLine = ERROR_LINE(),
         @ErrorProcedure = ISNULL(ERROR_PROCEDURE(), '-');
  SELECT @ErrorMessage = N'Error %d, Level %d, State %d, Procedure: %s, Line: %d, ' + 'Message: '+ ERROR_MESSAGE();
  RAISERROR (@ErrorMessage, @ErrorSeverity, 1, @ErrorNumber, @ErrorSeverity, @ErrorState, @ErrorProcedure, @ErrorLine);
END CATCH
END
/* RUN THE STORED PROCEDURE
EXECUTE gisowner.CreateTAX_BVW
Refresh Views
To refresh the tables, you should execute the stored procedure(s) created on a regular schedule to ensure the data is refreshed often enough to meet your reporting requirements but not so often it places a burden on your system. Below you can find an example script.
exec UNADMIN.CreateAssembly_BVW;
exec UNADMIN.CreateDevice_BVW;
exec UNADMIN.CreateJunction_BVW;
exec UNADMIN.CreateLine_BVW;
exec UNADMIN.CreateStructureBoundary_BVW;
exec UNADMIN.CreateStructureJunction_BVW;
exec UNADMIN.CreateStructureLine_BVW;
exec UNADMIN.CreateAssociations_BVW;
exec UNADMIN.CreateSubnetworks_BVW;
SAP HANA
Because SAP Hana doesn’t have materialized views the recommended approach is to use a stored procedure to create a column table that stores the current state of the data in default. The following stored procedure will persist the current state of the table from the default version, then create indices on the global id and object id columns.
/*CREATE STORED PROCEDURE*/
CREATE OR REPLACE PROCEDURE UNADMIN.CREATE_DEVICE_BVW
(OUT sql_code INT,
OUT sql_msg NVARCHAR(512))
LANGUAGE SQLSCRIPT AS
BEGIN
 DECLARE EXIT HANDLER FOR SQLEXCEPTION
 BEGIN
   sql_code = ::SQL_ERROR_CODE;
   sql_msg = ::SQL_ERROR_MESSAGE;
   RESIGNAL;
END;
sql_code = 0;
sql_msg = null;
IF EXISTS (SELECT 1 FROM M_TABLES WHERE SCHEMA_NAME = 'UNADMIN' AND TABLE_NAME='DEVICE_BVW') THEN
   DROP TABLE UNADMIN.DEVICE_BVW;
END IF;
CREATE COLUMN TABLE UNADMIN.DEVICE_BVW AS (
   WITH T0_ AS
   (SELECT OBJECTID, GLOBALID, ASSETGROUP, ASSETTYPE, ASSETID, SHAPE
    FROM
      (SELECT  OBJECTID, GLOBALID, ASSETGROUP, ASSETTYPE, ASSETID, SHAPE, ROW_NUMBER() OVER (PARTITION BY OBJECTID ORDER BY GDB_FROM_DATE DESC) RN_, GDB_IS_DELETE
       FROM     UNADMIN.Device
       WHERE    (GDB_BRANCH_ID = 0)) A
    WHERE RN_ = 1
      AND GDB_IS_DELETE = 0 )
   SELECT   OBJECTID, GLOBALID, SHAPE
   FROM     T0_
CREATE UNIQUE INDEX DEVICE_BVW_UUID ON UNADMIN.DEVICE_BVW ( GLOBALID ASC);
CREATE INDEX DEVICE_BVW_PK ON UNADMIN.DEVICE_BVW ( OBJECTID ASC );
END;
Refresh Reporting Table
To refresh the table, you just call the stored procedure associated with any tables you want to refresh.
CALL UNADMIN.CREATE_Assembly_BVW(? ,?);
CALL UNADMIN.CREATE_Device_BVW(? ,?);
CALL UNADMIN.CREATE_Junction_BVW(? ,?);
CALL UNADMIN.CREATE_Line_BVW(? ,?);
CALL UNADMIN.CREATE_StructureBundary_BVW(? ,?);
CALL UNADMIN.CREATE_StructureJunction_BVW(? ,?);
CALL UNADMIN.CREATE_StructureLine_BVW(? ,?);
CALL UNADMIN.CREATE_Associations_BVW(? ,?);
CALL UNADMIN.CREATE_Subnetwork_BVW(? ,?);
Comments
JeffTimm
In the PostgreSQL example I get
ERROR:  column "rn_" does not exist when I configured this to my data. What might be the issue there?
Also how would you incorporate Union All into this to combine more than one feature class with the same schema?
RobertKrisher
Make sure you've copied the entire procedure statement into your query editor. I just tested the expression in this article against a local PostgreSQL 13 database.
If you read the accompanying blog post you'll see that I recommend that you keep your materialized views simple and only maintain a single materialized view for each of your branch versioned tables. Any filtering, combining, or translating of data should be done with a reporting layer on top of the materialized views. This can be done by creating regular views against the materialized views, or by using some sort of reporting/business intelligence tool.
JeffTimm
Would my database source being an AWS RDS cause this not to work?
RobertKrisher
The AWS RDS engine are you using will determine the syntax you should use. If you're using one of the engines listed above then it should work (although we didn't test against AWS RDS) as long as you use the exact SQL provided. If you're using Amazon Aurora or one of the engines we didn't provide a syntax for then that would explain the syntax error.
JeffTimm
Do you have a tool available to iterate through your feature classes to create materialized view in postgres.  Creating them all manually is tedious at best.  Traditional versioning had an evw created for each FC already.  Is that something that will be available down the line?
RobertKrisher
There is currently no tool to perform this or any plan to develop one. If you want to create a reporting database of all your layers, I recommend you check out the Export Reporting Data tool from the ArcGIS Solutions team.
JackVan_Schenck
@RobertKrisher - from your 4/19/2024 response to @JeffTimm, is the best practice recommended by ESRI to use a python script to extract data from UPDM for reporting?  We are using SSRS to report tabular data for users that don't have or need ArcGIS software (e.g., accountants).
RobertKrisher
@JackVan_Schenck  The benefit of using that tool is that it will create a separate geodatabase for reporting, which means your accountants running reports won't affect the performance or editing experience of your mappers.
PierreloupDucroix
MVP Regular Contributor
Hello@RobertKrisher
Thank you for this helpful code.
I've noticed that when creating a materialized view like this, the globalId field is converted to a text field. Even registering it to the geodatabase doesn't resolve the issue.
As a result, it becomes impossible, for example, to create a relationship class with another table.
Do you have any idea how to preserve the globalId in a materialized view?
RobertKrisher
If you want to create a true geodatabase table that can be related to something else, I'd recommend you just use something like copy rows/features to create a copy of the table in default, or use something like the Export Reporting Data tool (part of the Utility Data Management Support tools) to create a copy of all the UN Classes that includes coded value domain descriptions, subtype names, etc
PierreloupDucroix
Hello, thank you.
I was able to modify the field type in the materialized view by updating, after registering to the GDB, the 'sde_type' property of the field in the 'sde_column_registry' table with the value 12 (the SDE type for GUID, apparently). It now appears as a GUID field type in ArcGIS Pro.
However, as you may know, it's impossible to create a relationship class between a table and a materialized view... I knew it wasn't possible with a regular view, but I thought it would work with a materialized one.
Anyway, I'm going to try the "Create Reporting Database" tool to see if it can meet my needs.
[EDIT] I believe you're talking about the "Export Reporting data" tool
dstrigl
@RobertKrisher
Shouldn't this (for Oracle) not like this?
ON UNADMIN.DEVICE_BVW ("SHAPE")
AllanBenvin_yyc
Thanks for all this. We rely heavily on versioned views in our databases. It is good to have this as an option with branch data. I assume there is a good reason that this uses materialized views vs regular views. In our case views would be preferred as it reduces steps and doesn't require adding more disk.
I took a shot at creating views using the query logic above. I found the draw performance was ok but if a selection was made then the performance was quite bad (40 seconds) on large-ish table with 400k records. To test performance, I created a script which would take a layer and export the first 5000 records (OBJECTID < 5001) to an FGDB. To export the native branch layer took 1.82 seconds, to export the view created on the logic above took 6 minutes and 54 seconds.
I took a shot at reworking the view and came up with an alternate query that performed much faster. The draw, selection and export time is comparable to the native branch layer. Of course, this view code is not official so I'm putting it below to see if anyone has any comments on the validity. I have tested this against a layer with multiple edits in multiple versions and have not found any issues with it so far. If this works then great, if not then we can look at the materialized views and all the extra work that entails.
Let me know your comments.
--View of DEFAULT version of branch data for SQLServer, maybe right, maybe not
CREATE OR ALTER VIEW SOMEOWNER.SOMETABLE_V AS
WITH Latest AS (
    SELECT
        GDB_ARCHIVE_OID,
        OBJECTID,
        ROW_NUMBER() OVER (
        ) AS RN,
        GDB_IS_DELETE
    FROM SOMEOWNER.SOMETABLE
    WHERE GDB_BRANCH_ID = 0
SELECT
    X.OBJECTID,
    X.GLOBALID,
    X.COL1,
    X.COL2,
    X.COL3
    X.SHAPE
FROM LATEST L
JOIN SOMEOWNER.SOMETABLE X
    ON X.GDB_ARCHIVE_OID = L.GDB_ARCHIVE_OID
WHERE L.RN= 1
  AND L.GDB_IS_DELETE = 0;
Update: my performance issues with the view are on SQLServer, Oracle seems to perform okay. For my updated view code it seems to perform equally well on Oracle and SQLServer.
JoeGuziStarkCountyOH
Greetings @AllanBenvin_yyc ,
     Thank you for sharing your method to create these views. It made more sense to me and I was able to replicate it with my data. I then ran the Feature Compare Geoprocessing tool to compare the actual feature class and the view I created, and I got positive results. They're identical, or pretty close. I really appreciate you sharing this. Thank you for everything and have a delightful day.
Sincerely,
Joe Guzi
AllanBenvin_yyc
I'm glad it is working. (whew!)
We have created a Pro tool that creates the *_BVW views for our branch versioned data. This makes the creation and maintenance of the BVWs much easier.
RobertKrisher
To be clear, creating views instead of materialized views is against the best practice and recommendation of this article. The performance problems encountered with using a dynamic view are the reason why we suggest using a materialized view.
AllanBenvin_yyc
Despite having the name "view" in it a materialized views is not a database view. It is a copy of the data at a point in time. Since it is a table and can be indexed, it does perform faster. The materialized view also has the drawback of doubling storage requirements. This becomes an issue with large datasets such as our parcel fabric.
We have been using spatial views for 20 years in our organization. Having these not be supported on branch data is a big deal. In our case we use the branch views described above to create registered staging views for replication to our published geodatabase. We find performance to be comparable to drawing the data in ArcGIS Pro.
If there is not efficient way to query or draw branch versioned data, I'm curious how ArcGIS Pro does it.
RobertKrisher
@AllanBenvin_yyc Because SDE doesn't use a static query for accessing the data like a view does. Take a look at how where clauses are applied to the branch version analytic and it will start to make sense. If you have a limited number of access paths you're supporting with dynamic views, you can recreate optimized queries similar to what ArcGIS Pro is doing. But this is an advanced activity that requires a strong understanding of SQL.
Also, it's not doubling the storage requirements of the table. You're duplicating the storage of only the active rows in the table, not the active rows + N years of history.
Version history
Last update:
‎11-18-2025 07:15 PM
Updated by:
Contributors
