Zoning with invalid geometry
1614
12-21-2021 10:27 AM
spragujs
I'm trying to load my zoning layer into Urban and have set up all the types, repaired the geometries, deleted items with blank geometry, and run densify on it, but I still get an invalid geometry error when trying to load it into Urban.  Any other tips I can try?
DanPatterson
MVP Esteemed Contributor
Check Geometry (Data Management)—ArcGIS Pro | Documentation
there are 2 validation methods, it doesnt hurt to check with both if your data location/type permits it
... sort of retired...
SilviaCasas
Hi @spragujs ,
There are a few more reason why you could be getting the invalid geometry error. You've already done the recommended, but we have found some times geometries with null areas that can break the process. Also, if you have slivers in your geometries, it can also cause issues in the loading. Hope you can complete your loading after a little cleanup.
Silvia
DanPatterson
spragujs
Thank you both, I'd mistakenly assumed that repair geometry would fix all the issues, but there was the one remaining in check geometry.  It's all working now!
