I am working on a plan where I'd like to work with the generation of buildings based on FAR og Coverage restrictions. For Norwegian plans these restrictions are not connected to the land use types or the zoning types directly, so I have been adding them using overlay types or parcel overrides. I guess another option is to create a copy of the land use type/zoning type within the plan and give this copy the FAR and Coverage restriction.
The problem I am writing about is that I am not able to add a coverage value other than 0% or 100% using the parcel overrides. When I try to add a coverage value of 50%, I get the error message "maximum value exceeded". When I try to write 0.5 the program automatically rounds my answer to 1, which gives a coverage of 100%.
The same problem does not apply to FAR.
Solved! Go to Solution.
@MLindauLanghelle we just deployed a fix for this issue. Thanks again for reporting this!
Hi @MLindauLanghelle
Thanks for reporting this! I can reproduce the issue on our end as well. We will look into this asap.
I can confirm that the problem only applies to parcel overrides, not to overlays and zoning types.
