Scenario-specific elevation layers in ArcGIS Urban
1013
7
03-10-2022 06:34 AM
Status: In Product Plan
JEngvall
New Contributor II
It would be great if you could use different elevation layers for different scenarios of an project/plan. While editing terrain might be a bit too complex for ArcGIS Urban, different terrain is something normal in scenarios in CityEngine.  As an user it would be expected that different scenarios would be able to contain different terrains/elevation layers in ArcGIS Urban as well, but the editing of the elevation layer might take place in ArcGIS Pro or CityEngine. It would be very useful for a city planner.
7 Comments
Till_Schmid
Thank you for this idea, @JEngvall!
I'd like to point out that projects already support custom elevation layers per scenario. In more detail, this is possible by uploading a "scenario design visualization" or "scenario design context" web scene. Those layers can be defined in the scenario settings. If the web scene contains a terrain layer, the terrain in Urban is automatically adjusted.
This is currently only possible for projects, not for plans.
JEngvall
OK thank you! This does not seem to be mentioned in the resources about ArcGIS Urban so if this information could be added it would be helpful. Is there a reason for it to only be available with projects and not plans?
Till_Schmid
Thank you for this note, we will add more information to the documentation.
I am not sure about the reasons why this feature is currently only available for projects. I will keep this idea open and will discuss this request internally. Thanks!
Till_Schmid
I quickly checked within our team and there are technical limitations with the procedural building generation that currently prevents us from allowing scenario specific elevation layers for plans.
JEngvall
OK, thank you @Till_Schmid for the help! This is important info for the user.
Till_Schmid
Till_Schmid
