Question for Design a map with ArcGIS Pro and Adobe Illustrator ?
1271
10-18-2023 10:21 AM
DEAF_PROBERT_68
Honored Contributor
I am doing this tutorial and this one confuse me is when you open Adobe Illustrator.
So I am following here the tutorial here : https://learn.arcgis.com/en/projects/design-a-map-with-arcgis-pro-and-adobe-illustrator/
I worked through all of the exercise the ArcGIS Pro all the way until you see : Bring the map into Adobe Illustrator.
Then scroll down until you see this :  Open an AIX file.
What I am confuse about this is  the number  4.
 On Number 4, do you mean open the File at the Adobe Illustratoer menu ?
Look at this screenshot ?
I just wanted to make sure I am doing the right thing or clarify .
HeatherSmith
Esri Alum
@DEAF_PROBERT_68 yes, you are doing the right thing!
HeatherSmith
Esri Alum
