point selection based on buffer
4377
09-05-2020 03:37 AM
T_Zett
Hello everyone,
I would like to select specific points from my dataset based on their proximity to each other. For this I would  like to create a buffer around all the points and then only select those, that overlap with at least 3 other buffer zones (to select for areas with high point density).
Is there a way to do this within ArcGIS? Any help would be appreciated.
Thanks in advance!!
DavidPike
MVP Notable Contributor
DavidPike
There's better workflows, but for a beginner to GIS I might advise:
1. Create buffers from all your points - e.g. buffer all points by 100m
2.Run the Count Overlapping Features (Analysis)—ArcGIS Pro | Documentation tool. (if you don't have pro this may be a bit harder and need some spatial joins etc. let me know if this is the case)
3. use the 'select by location' tool (having selected only those buffer features with an overlap count >= 3) to find the original points within those areas.
T_Zett
Hello David,
thank you for your help, unfortunately I don't have pro, I'm currently
working with 10.7. I have been looking for a way to do the count spatial
joints for this version, but have found nothing so far.
Thank you for any help in advance,
Theresa
DavidPike
This seems to be a fair workflow - Count Overlapping Polygons ArcMap - YouTube
T_Zett
That one is great, thanks so much!
HeatherSmith
Esri Alum
The kernal density or point density tools may also help you: An overview of the Density toolset—Help | ArcGIS for Desktop
