Is there a bug in this lesson?
2577
08-10-2020 08:30 PM
EricaPrice
I am doing the lesson Predict floods with unit hydrographs | Learn ArcGIS and on the section for "Create a Unit Hydrograph: Prepare the Unit Hydrograph Table," #13, I am getting this error:
ERROR 002717: Invalid Arcade expression, Arcade error: Semicolon or new line expected, Script line: 1
Failed to execute (CalculateField).
Is there something wrong with the code !Count! * 30 * 30?
Thank you,
Erica
XanderBakker
Esri Esteemed Contributor
Hi Erica Price
David is correct. This is an error in the lesson:
For Arcade you should use:
$feature["Count"] * 30 * 30
// or
$feature.Count * 30 * 30
You can also change it to Python and use the formula mentioned in the lesson:
!Count! * 30 * 30
DavidPike
MVP Notable Contributor
Looks like Python Field Calculator syntax?
I don't use Arcade unfortunately, but the documentation suggests a syntax like:
$feature["fieldname"] * 30 * 30
XanderBakker
Hi Erica Price
// or
!Count! * 30 * 30
HeatherSmith
Esri Alum
Thank you Erica, David, and Xander. We will make this fix for our next lesson release!
