Classification using Raster Calculator
1333
06-14-2021 12:43 AM
AzmeryIqbal
Hello,
I am trying to classify an image using raster calculator and conditional function, however, I can't seem to classify it. Can anyone kindly suggest what went wrong? Ps. The code is attached below (Int_tif2 is my image's name):
Con("Int_tif2"<= 110,0,"Int_tif2"),Con(("Int_tif2"> 110) &("Int_tif2" <= 250),1,"Int_tif2" ),Con(("Int_tif2">250) & ("Int_tif2" <= 350),2,"Int_tif2"), Con("Int_tif2" > 350,3,"Int_tif2")
Thank you
DanPatterson
MVP Esteemed Contributor
Con("Int_tif2"<= 110,0, "Int_tif2",
    Con(("Int_tif2"> 110) &("Int_tif2" <= 250), 1,
	Con(("Int_tif2">250) & ("Int_tif2" <= 350), 2,
	    Con("Int_tif2" > 350, 3, "Int_tif2"))))
perhaps, but if it is < 110 or > 350 it will be classified as Int_tif2, if that is correct
... sort of retired...
JayantaPoddar
Looking to classify the raster into 04 classes, i.e. 0-3?
You can check the following expression.
Con("Int_tif2"<= 110, 0, Con(("Int_tif2"> 110) &("Int_tif2" <= 250), 1, Con(("Int_tif2">250) & ("Int_tif2" <= 350), 2, Con("Int_tif2" > 350, 3))))
Think Location
