Color connotations and associations
1477
05-21-2024 05:13 AM
HeatherSmith
Esri Alum
5 3 1,477
Colors are never neutral. They affect how people think and feel about your map. As a cartographer, you should be aware of the connotations and associations carried by the colors you use. They can be powerful tools to help you communicate more clearly. But if you ignore them, they can just as easily sabotage your map’s message. The two videos below share examples of color choices based on associations and connotations. The examples given are in ArcGIS Pro, but this advice is relevant to any mapping situation.
 (Watch the video with subtitles here: https://mediaspace.esri.com/media/t/1_pbjpq2zm)
 (Watch the video with subtitles here: https://mediaspace.esri.com/media/t/1_j4e7qnwn)
Takeaways:
  • If there’s a color that’s normally associated with your subject, you should probably use it in your map.
  • What colors will your audience expect to see on this map? Try those first.
  • Color connotations and associations can be overpowered by other signals in your map.
  • Color connotations vary (sometimes dramatically) between cultures.
Further learning:
Emily Meriam is a pro at exploiting color connotations and associations. You can learn more about how she does it in the following articles: Creating a meaningful temperature palette and Sunset Colormapping.
You can find more videos like these in the Quick Cartography playlist.
Data sources:
The data in these videos comes from the following sources:
3 Comments
Contributors
About the Author
Cartographer and Content Engineer on the Learn ArcGIS team at Esri.
