Map view dashboard
1724
06-30-2022 02:08 AM
DrJumaKhudonazarov
I have the results of Survey123 and try to make a dashboard can someone help me with how to do this?  Also when I open the map view I can't see the dots in the map?
ZacharySutherby
Hello @DrJumaKhudonazarov
For the second question this is a known issue with the classic map viewer, please see this FAQ documentation for more information. What's happening is your feature service doesn't have query enabled on it so the classic map viewer is not able to query the features. In order for the features to draw in the classic map viewer you will need to modify the settings of the feature service to enable query. The easiest way to do this is to change the setting "What features can editors see?" to "Editors can see all features".
For the first question this ArcGIS Blog may be a good place to start for configuring an ArcGIS Dashboard.
Thank you,
Zach
