Zero is being dropped from zero-padded domain values
673
05-14-2021 05:49 AM
CarlBeyerhelm
I have a zero-padded coded value domain in a Survey that has been working as expected in a select_one FOREST question until just recently, when the survey started dropping the leading zero from the coded value.
See CodedValueDomain.png below to see the FOREST list, and see Result.png below to see the recent change in output result.  The Admin_Region field in Result.png is being hard-wired to "03", so its result has not changed.
The Excel cells are formatted at text, and I've set bind::esri:fieldType as esriFieldTypeString.
Any ideas would be appreciated.  Thank you...
CarlBeyerhelm
OK, thank you.
