wireless barcode scanners
737
10-12-2017 06:30 PM
TylerFord
Has anyone used a wireless bar code scanner with Survey 123.... I know I can just take a picture of the bar code with the tablet or phone I'm using to run the survey but there is a strong possibility that the bar code will be in a pit covered in mud. I don't want to put our assets in more danger then they already are so I was hoping to use a wireless bar code scanner. Any Comments / thoughts?
#wirelessbarcodescanner
JohnathanHasthorpe
Hi Tyler
We have tested against a bluetooth Symbol CS4070 scanner device and it works really well at scanning.
The phone sees it as a keyboard - so you can use it to populate any of your text based survey questions.
There is a button that enables you to show/hide the actual keyboard.
Cheers
John
